Fuel injector/engine cleaner
Old 05-18-10, 08:15 AM
bryanc182
bryanc182's Avatar
Default Fuel injector/engine cleaner
Anyone recommend a good fuel injector and engine cleaner to use? I'm looking for something to add before or after i fill up my tank. ANy help is greatlly appreciated!
Old 05-18-10, 08:34 AM
spine911
spine911's Avatar
Chevron Techron.
...is the repackaged Porsche, and BMW injector cleaner, independent lab tested
Old 05-18-10, 08:47 AM
BinaryJay
BinaryJay's Avatar
The same stuff is apparently in Gumout Regane. Which is not helping me one bit so far.
Old 05-18-10, 07:54 PM
jdaniels07
jdaniels07's Avatar
I used Redline and have been doing so for 10+ years. I haven't had any issues with fuel injectors in any of our cars.
JD
Old 05-19-10, 02:29 PM
steviej
steviej's Avatar
I use Chevron w/Techron twice year on my last three cars. Not really a controled study, but experience says it isn't hurting and I haven't had any fuel injector problems in any of the vehicles.
steviej
Old 05-19-10, 03:58 PM
designo
designo's Avatar
If your car has a direct fuel injection system, check with your local gas station about sulfur levels in their fuel.
Choose the fuel with the least sulfur content and your problem is solved. It isn't always about octane rating, it's the type of fuel delivery system you have and fuel content you use.
Old 05-20-10, 11:09 AM
LexFather
Guest
Posts: n/a
I've used them all including Marvel Mystery Oil. I like Shell V Power....
Old 05-20-10, 11:49 AM
Coolpop
Coolpop's Avatar
Does the stuff ever go bad? I bought a case of the Chevron fuel injector cleaner about 3 years ago and I still have three bottles left. Just curious.
Old 05-20-10, 11:54 AM
BinaryJay
BinaryJay's Avatar
If it's sealed and kept out of the sun the stuff probably lasts "forever".
Old 06-28-10, 08:17 PM
Trexus
Trexus's Avatar
I like Lucas Injector Cleaner. Kragen/O'Reilly Auto Parts is having a sale buy one 5.25 oz Lucas Injector Cleaner and get one free. They also have buy one get one free Valvoline fuel injector cleaner as well...
Old 06-29-10, 10:01 PM
HotShotEng
HotShotEng's Avatar
First of all, I'm not sure why you want to use the cleaner in the first place. Today's gasoline all ready has additives to prevent deposits from forming on the injectors. Having said that, you should be concerned. The same chemicals used to remove deposits not only clean the injector they also eat away at the injector itself. The most common limit with these cleaning systems is three times then the injectors will need to be replaced. I suggest unless you are experiencing problems such as rough idle, hesitation or no power, don't add any of the additives currently on the market.
__________________
Old 06-30-10, 05:06 AM
BinaryJay
BinaryJay's Avatar
__________________
I think this is misinformation. I think most reputable products out there will not harm much of anything. The real debate is whether or not they actually help anything or not.
menty
Performance & Maintenance
06-12-21 05:01 PM
Shawnmack
01-28-21 08:23 AM
Nosugar
08-16-14 01:38 PM
kreativ
Maintenance
21
07-28-02 02:06 AM
zushwa
Maintenance
23
01-28-02 03:32 AM
Quick Reply: Fuel injector/engine cleaner
