Trunk Sensor?
Old 10-14-09, 11:25 PM
heyitzalex
heyitzalex's Avatar
Default Trunk Sensor?
Is there a trunk sensor somewhere? Just installed a seibon trunk and the trunk opener does not work anymore. Can't open from the keyfob, or from the button inside. The trunk only opens by using the key or the latch from the inside. When I press the button on the keyfob, I get a long "beep", but trunk doesn't budge. Auto-close function doesn't work either. The button in the glove box is not set to valet.
Funny thing is, the motor worked perfectly fine before we put the harness in the seibon trunk. I think it might be the motor since there is TSB on it; its just weird how it happened to break when it got transferred to the new trunk. I want to see if there is a fix before I take it in to the dealer.
Old 10-15-09, 11:45 AM
The G Man
The G Man's Avatar
What is a seibon trunk ?
Old 10-15-09, 11:54 AM
Stormforge
executive matchup
Stormforge's Avatar
i assume the seibon trunk is lighter than the oem trunk?
Old 10-15-09, 12:20 PM
rominl
exclusive matchup
rominl's Avatar
seibon, is that the CF trunk?
Old 10-15-09, 12:21 PM
rominl
exclusive matchup
rominl's Avatar
http://www.seiboncarbon.com/pdut_det...asp?ItemID=651
Old 10-15-09, 12:34 PM
IXI187IXI
IXI187IXI's Avatar
yes seibon makes cf pieces
Old 10-15-09, 01:38 PM
heyitzalex
heyitzalex's Avatar
Yes, the seibon trunk is not much lighter than the factory trunk. It's not double sided cf, and its still relatively heavy. Can't seem to figure out why the latch doesn't want to open automatically.
Old 10-15-09, 08:34 PM
LMN_Sins
LMN_Sins's Avatar
Contact seibon, maybe ?!
Old 10-16-09, 12:45 AM
heyitzalex
heyitzalex's Avatar
The entire wire harness and trunk opening mechanism is transferred over from my oem trunk to the seibon one. I was wondering if there was some sort of sensor that knew when to autoclose, or maybe something that triggered the keyfob. Of course it can be the motor.
Old 10-16-09, 08:21 AM
The G Man
The G Man's Avatar
Maybe there is a magnetic sensor on the lock.
Old 10-16-09, 01:58 PM
heyitzalex
heyitzalex's Avatar
Because the harness was unplugged, it needed to be reinitialized by Lexus. But I guess that didn't work and the problem was the junction block, part was ordered by Lexus and will be here in a few days. I guess it is some block by the fuse box or something, I'll post the part number later for future references.
Tmac334
GS - 1st Gen (1993-1997)
09-30-18 04:17 PM
peasodos
02-15-17 08:16 AM
chrisv78
05-29-13 09:37 AM
palidino
03-18-13 02:27 PM
shiny250
03-12-10 08:13 AM
Quick Reply: Trunk Sensor?
