Foul odor! :mad:
I am telling you, try the cologne and the AC on recycle. It works well for me. I start the car and the cabin fills with the smell of Gucci cologne. I am still wondering if the problem in AZ is smaller because of the total lack of humidity. ( usually 4-12%)
Get yourself some Milton tablets/fluid (or whatever the US equivalent is of it - baby bottles/teats steriliser).
Mix that up to the amount needed by the system (empty the current contents and flush with water first), then use it to get the fluid in all the pipework.
Leave it a few hours to work its magic, then flush, and refill with a decent quality screenwash - what Toyota/Lexus recommend sell?
I had the same issue with my G35 in the past I finally got rid of the smell by filling it with water and a little soap then spraying my wipers until the reservoir was drained, did that a couple times and finally the smell went away.
Sorry for the late response. The smell went away. It was FOUL smelling too, like B.O. from trash+sweat combined with moldy water, a smell i don't want to witness again. Flushed with with DI water and car wash soap, ran the thing for a good 5-10 drains, then added new windshield washer fluid.
Can't febreeze that, ur crazy! LOL
Change your cabin filter also! The reason for this is that condensation builds within the A/C system and you don't shut off the AC and run a air-only flush before you leave your vehicle. (meaning turn off the A/C but run the air still for about 5-6 minutes before you get to your destination). Witnessed this on my gf's old camry and it's happened again on her new camry, will be taking it back to yota for a fix
http://www.imcool.com/articles/airco...vap_stinks.htm
Google "foul smell in car A/C vents" that should give you quite a few solutions!
http://www.a5oc.com/forums/a5-s5-top...tml#post100615
Also found that on the a5 forums, I tried it and it didn't work, but who knows! It might work for u!
LMAO brabus, i'm guessing you've gotten that experience too? Mine's does it ONCE in a full moon, I usually have my windows down and A/C off, I like people seeing who's driving that lexus hahaha
Pineapple
08-20-07 09:21 PM
