Noooooooooo!!!!!!!!! (broke locking lug)
So I'm replacing the rear brake pads (super simple, BTW) and I go to loosen the lug nut with the locking pattern on it and the end of the lug nut broke off!
I've put some JB Weld on the "key" and stuck it on the broken bolt. It should be cured by tonight. I'm crossing my fingers it works. If not, anyone else have any ideas?
Not just the wheel, but the whole rear assembly! Just make sure you don't glue the wheel to the stud and to the rotors itself.
I don't think JB Weld will hold up considering how much torque you'll be putting on the bolt itself. If it works, good job and I will try that next time!
Good luck!
Good luck!
Unfortunately, the closet Lexus dealer is an hour away
The JB Weld did NOT work. To be fair, the nut was on VERY tight and I didn't let it set for a full 24 hours. Anyway, I took it to a local tire shop and after about 15 minutes of using one of those sockets that literally dig into the lug nut, he got it off! He didn't even charge me!!!! I tried to pay him SOMETHING, but he refused. He'll definitely get my business in the future. I stopped by the Toyota dealer and bought a single non-locking lug nut to replace the broken locking nut for a grand total of $5. I don't really see the point of the locking lugs on these standard 17" wheels. They're a headache. I'll be replacing them all soon. I need to get a replacement key first since mine is now trashed. BTW, it took me maybe 5 - 10 minutes to replace the brake pads on the rear driver's side once I was able to get the wheel off! It is sooooo simple! (I replaced the rear passenger side last night before I hit a roadblock with the broken lug).
Hacked CL to become a Mod
ouch same thing happened to me...so i brought it over to Toyota and they have a set that opened it no problem...you can always get some shop to drill it out
executive matchup
Dealer was doing TSB on rear brakes and said we were down to about 1mm! They wanted $180 for the rear brake job. I said no thanks. Akebono pads from autohausaz dot com cost me about $65/shipped. Seeing as how they already had the rear wheels off for the TSB, I can't believe they wanted all that labor cost for the simplest 5 minute brake job I've ever seen in my life!!!
They also said they couldn't find a leak in my rear tire (I hadn't even looked for it as yet). While I had the tire off doing the brake job, a bright silver screw head was staring at me from the center of the tire tread! Lexus of South Atlanta BLOWS!!!!!!!!!
