Need help with a Nav Hybrid Disk Mod.
Old 03-27-08, 07:23 PM
wimbley100
wimbley100's Avatar
Default Need help with a Nav Hybrid Disk Mod.
HELP !!!
I just tried the Nav overide reco by creating a hybrid Nav Disk. I purchased a 5.1 Nav Disk and followed the directions on the posts to replace the Loading.KWI file from the 5.1 disk to my 6.1 files. Everything copied over fine but when I installed it, I got an error message. Now the the nav doesn't work and the disk can't eject.
Anyone have any ideas on how to get it going again ? Sounded like a simple mod but now I seem to have no nav.
Old 03-27-08, 08:19 PM
fazooley1
fazooley1's Avatar
Yes go into menu and press the bottom and top left at onve and that will eject it. Im pretty sure this is what you need to do I did the exact same thing. Then just rhrow your 7.1 disk in and it will update and be back to normal.
Frankie
Old 03-28-08, 10:19 AM
wimbley100
wimbley100's Avatar
Thanks but right now, the hybrid disk is inside the player and will not eject. None of the Nav buttons are working at all. I have a message that the program can not be read and to see the dealer... along with some Japanese letters.
I am open to any suggestions.
Old 03-28-08, 10:22 AM
Lexus GS3
Trouble Maker
Lexus GS3's Avatar
Use your index finger and tap the upper right hand corner twice. Your hybrid disc should now eject. good luck!!
Old 03-28-08, 10:25 AM
wimbley100
wimbley100's Avatar
Even without any icons on the screen ? Right now, I only have the error message.
Old 03-28-08, 10:29 AM
Lexus GS3
Trouble Maker
Lexus GS3's Avatar
yes tap the upper right hand corner with your index finger twice on the screeen..
Old 03-28-08, 10:36 AM
wimbley100
wimbley100's Avatar
Awesome... I will give that a try.
Old 03-28-08, 01:56 PM
wimbley100
wimbley100's Avatar
Thanks to everyone that responded... That did the trick ! Two taps and it came right out. Club Lexus is a beautiful place...
Old 03-28-08, 02:04 PM
Lexus GS3
Trouble Maker
Lexus GS3's Avatar
You are welcome!!!
Old 03-28-08, 04:23 PM
ecount00
ecount00's Avatar
blending a 5.1 and 6.1 should be doable. If you're going to retry it, be careful about getting the right blank dvds (memorex+R DL usually work) and burner software that is proven. Roxio seems to work better than Nero for some reason for this. the nav dvd readers are really touchy. the last variable is the dvd burner itself. that's trail and error.
you can try burning a straight backup copy of your 5.1. no hybrid, just a straight copy. be sure to burn a 'data' dvd and put that in. if it won't read, then the blank dvd type, the burner software or the burner itself is likely the problem. if the backup does work, then you've cleared those 3 hurdles and the problem is probably something with your combo technique.
Old 03-28-08, 07:58 PM
wimbley100
wimbley100's Avatar
Thanks... I am trying it again. I am burning it on a Mac laptop. That could be the issue. I will do the trial and error tests to see if I can get it refined. I did find another good post that I am following to see if that will work out better.
Thanks for the help.
Mickeypro
03-24-14 02:34 PM
garyr
01-07-11 11:32 AM
fazooley1
02-01-08 08:47 AM
Addiction2
11-06-07 05:44 PM
Quick Reply: Need help with a Nav Hybrid Disk Mod.
