Making the ML sub sound better
Old 03-10-15, 02:42 PM
  #61
DrexLex
DrexLex's Avatar
Originally Posted by Tantrix
so just to clarify, you are adding a separate amp for the ML subwoofer, which leaves the ML amp to just power the rest of the ML speakers in the car cabin right ?
Exactly. But the sound quality improvement is due to careful tuning of the tone control in the head unit in combination with the amp's internal bass EQ.
does anyone know what size the ML subwoofer is ? is it a single subwoofer set up ?
It's a 10", single unit, single voice coil of some higher than normal impedance.
I'm more concerned with the ML subwoofer deteriorating at the rubber surrounds.
I drove my car off the lot 10 years ago in June, and the woofer has been driven this way almost that whole time. But I don't abuse it, and it also stays out of the sun.
I used to have a 2001 LS430 and the surrounds on the cheap subwoofer were the first thing to deteriorate.
Old 03-10-15, 02:48 PM
  #62
L's TLS
L's TLS's Avatar
does anyone know what size the ML subwoofer is ? is it a single subwoofer set up ? I'm more concerned with the ML subwoofer deteriorating at the rubber surrounds.
EDIT: DrexLex answered your questions.
I'm interested in the quality of the ML subwoofer too. I have read about IS guys complaining about blown or deteriorated but haven't seen anything in the GS side yet and DrexLex says he's still running strong on this set up. However, if it does deteriorate, I'll just add an aftermarket since I've run everything need already (wires and amp).
I ordered a small JL audio amp to push this thing. Looking forward to cleaning up the bass in the car. I'll report back with results.
Old 03-10-15, 07:24 PM
  #63
verly6565
verly6565's Avatar
does anyone no if the the non ml sub is the the same as the ml sub
Old 03-11-15, 12:55 AM
  #64
DrexLex
DrexLex's Avatar
^^ I think it is a dual voice coil unit, so it's different. The ML sub has a single voice coil.
Old 03-11-15, 04:39 PM
  #65
verly6565
verly6565's Avatar
i wonder if i swap in a ml sub in my non ml..so i could put that amp in
Old 03-11-15, 05:03 PM
  #66
DrexLex
DrexLex's Avatar
The new amp can drive your sub. Just wire the two voice coils in series.
Old 03-12-15, 04:45 AM
  #67
verly6565
verly6565's Avatar
Does anyone have the specs on the ml and non ml subwoofers
Rms ,ohms
Old 03-12-15, 11:46 AM
  #68
DrexLex
DrexLex's Avatar
Rms ,ohms
The ML subwoofer is said to be 12 ohms.
All the amps in the standard system are standard bridge amps. To reach 134W total rated output from 7 amps implies the speakers are all ~4 ohms. The subwoofer would be 2 sets of 4 ohm voicecoils. It ought not be rated at less than 100W total.
Why do you ask, if I may ask?
ADI$A69
32
09-13-16 07:00 AM
NYC ES3
IS F (2008-2014)
22
11-28-12 07:19 AM
ap65
ES - 5th Gen (2007-2012)
11-22-11 06:13 AM
KINGLS430
09-24-11 09:35 PM
mfb
08-05-02 02:19 PM
Quick Reply: Making the ML sub sound better
