Front Door Lock Issue (Not the actuator)
Old 06-11-15, 06:33 PM
marcman804
marcman804's Avatar
Default Front Door Lock Issue (Not the actuator)
I recently replaces my front speakers and when I put the door panel back on I noticed the passenger side door would not lock. I can hear the actuator move but the only way it will lock is manually with the key. I took the panel back off and noticed the plastic end of the cable where it connects to the door is broken, you can see in the picture. Does anyone know a fix for this? I tried to glue it back but it would not hold.
Attached Thumbnails Front Door Lock Issue  (Not the actuator)-20150611_205352.jpg
Old 06-11-15, 07:29 PM
Mr Jokster
Mr Jokster's Avatar
With some searching, you'll find a few threads on this; its pretty common. There are a few things that people have done, but everyone got together in a powwow and found out that combining the different fixes worked best. I'm pretty sure this is what I did too cause it happened to me. Gluing it is ok, but will definitely break again, but pairing the glue with getting a straightened paper clip and bending/wrapping it around the 2 separate pieces will hold it together. I did mine a couple years ago and its been fine ever since gotta wrap it nice and tight though, thats very important. The initial bend/wrap is the hardest, but once its done, the rest of the wrapping is very easy.
Old 06-11-15, 08:25 PM
marcman804
marcman804's Avatar
Thanks man. I searched and searched but everything seemed to be for the actuator. Could you post a link to the thread if you don't mind.
Old 06-12-15, 06:14 PM
Mr Jokster
Mr Jokster's Avatar
Well I'm sure one of the actuator threads had it, just gotta read man
https://www.clublexus.com/forums/gs-...-broken-3.html
jprebb
07-18-16 12:40 PM
Twister773
09-22-12 01:03 PM
napa2u
08-08-11 09:08 PM
LexLuger31
07-02-11 11:27 AM
Bri-Guy
05-17-08 07:45 PM
Quick Reply: Front Door Lock Issue (Not the actuator)
