Hid fog question
Old 03-03-15, 12:54 PM
Tnguyen9i6
Tnguyen9i6's Avatar
Default Hid fog question
For anyone who has hid in their fogs, are you running a relay as well or just popped a kit in and called it a day? Any help is appreciated
Old 03-03-15, 01:35 PM
newgsman
newgsman's Avatar
Just popped in a kit. Been good for over two years now except one bulb burnt out about a month ago. Too cold to change it out right now.
Old 03-03-15, 01:37 PM
Debonair
iModerate
Debonair's Avatar
Plug and play w/o issue for years.
Old 03-03-15, 01:44 PM
Tnguyen9i6
Tnguyen9i6's Avatar
Did you guys have to run relays as well? Or are we talking just the plain ol ballast and bulb? Ac of course
Old 03-03-15, 01:52 PM
PeteGS300
PeteGS300's Avatar
Plug & Play being fine so far.
Old 03-03-15, 01:55 PM
Tnguyen9i6
Tnguyen9i6's Avatar
Damn am I the only one that had a issue? Lol the ballasts I was using had relays on them. Passenger side igniter for the oem lows melted, blamed the his fogs.. But possibly the relay was in a stick position on the fog that made my low melt..they share the same line is what someone told me
Old 03-03-15, 03:12 PM
MrG4Life
MrG4Life's Avatar
Which brand did you go with? I'm using a plug & play kit with slim ballasts for years and have no issues.
Old 03-04-15, 07:00 AM
Tnguyen9i6
Tnguyen9i6's Avatar
Not sure of the kit name as it was some left over ballasts. Let me reiterate my question lol, is anyone running a relay with their kit? Or using a canbus kit?
Old 03-04-15, 09:02 AM
Sphan519
Sphan519's Avatar
I'm running a relay kit for my HID fogs, connecting straight to the battery.
Old 03-04-15, 11:01 AM
Debonair
iModerate
Debonair's Avatar
So far there are 4 without (plug & play) and 1 with, not counting you. What are you looking to find out with these questions, other then a head count of those with and without extra wiring and relays?
Old 03-04-15, 02:10 PM
MikeFoxx
MikeFoxx's Avatar
5 for plug and play: xenon depot hid fog kit on almost everyday since installed no issues.
Old 03-05-15, 06:58 AM
Tnguyen9i6
Tnguyen9i6's Avatar
Mainly if I'll need to run a relay or not. I'm still debating if I want to run the hids in the fogs. The kits I usually see are just ballast and bulb.
Old 03-05-15, 08:38 AM
Debonair
iModerate
Debonair's Avatar
Everyone who says "plug & play" is essentially running without relays. My fogs even had the yellow insert and were on almost all the time. Never had an issue with wiring or melting plastic. The choice is yours but I for one say to save your time, and money, and just plug them in and enjoy.
Old 03-05-15, 05:43 PM
mikobangz
mikobangz's Avatar
I use a relay for mine. They were plug and play initially from iJDMtoy but for some reason one ballast kept going out and I'd have to replace it so I bought a relay in hopes to stop the cycle but recently my passenger side ballast stopped working but now works fine. Usually just my driver side is on when I start the car and I have to turn my fogs off then back on for them both to turn on. It used to be just the passenger side then I'd have to toggle off and on for my drivers side. It's confusing and it's my fourth ballast, idk what the problem is.
Old 03-05-15, 08:30 PM
Tnguyen9i6
Tnguyen9i6's Avatar
Funny thing I was having that same kinda issue. Found out the bulbs I was using were DC and not AC. Switched the bulbs and they worked fine. Until my oem ballast igniter plug melted. I blamed it on the hid fogs but couldn't pin point if I needed a relay or not because most are not using one and a few are.
Quick Reply: Hid fog question
