01 Lexus GS 430 still thinks key is in ignition after removal
Old 08-19-14, 11:31 PM
superjohn
10th Gear
superjohn's Avatar
Default 01 Lexus GS 430 still thinks key is in ignition after removal
I occasionally have a problem where the car still thinks that the key is in the ignition
after turning off the car and removing the key from the ignition. The steering wheel won't retract, the door beeps when I open it, the door locks won't lock, etc.
I have to put the key back in and pull it out several times until it detects i removed the key.
Does anyone know what can cause this problem?
2001 Lexus GS430
Old 08-20-14, 12:43 AM
Lexusjg1
Lexusjg1's Avatar
Once before I pulled my keys from the ignition very slow just by chance. And the exact same thing you described happened. So I repeated it a few times and sure enough the same thing happened if you pulled the key out slow enough. In your case it could be the mechanism that detects when the key is inserted sticking or staying pushed in. When you remove the key it should go back in place and you here a little clicking sound. Try spraying some Wd-40 on your key then insert it a few times that might help.
Old 08-20-14, 01:58 AM
gsean400
gsean400's Avatar
Try resetting the computer, disconnect the battery for 20 mins.
Smileme
11-13-19 08:05 AM
reedsrx300
RX - 1st Gen (1999-2003)
11-02-17 02:41 PM
Fordrick
NX - 1st Gen (2015-2021)
08-21-15 12:25 PM
kdb0925
IS - 1st Gen (2001-2005)
11-25-07 01:44 PM
LX450SD
CL of Southern California
01-14-06 11:21 AM
Quick Reply: 01 Lexus GS 430 still thinks key is in ignition after removal
