1998 (2nd generation) lexus gs300 won't start need help!!
Old 06-10-14, 06:31 PM
Bbruno
Bbruno's Avatar
Default 1998 (2nd generation) lexus gs300 won't start need help!!
I have a 1998 lexus gs300, I was working on my driver side door lock rod. It was disconnected . While working on it the windows kept going up and down so I disconnected the negative battery once done reconnected the battery started the car. Car idled rough then shut. Check engine light was on. Checked it tbs was on. Changed it out . Then car just cranked over but never started. Checked fuel pump. Was not coming on with key in on position . I changed the fuel pump, the relay, the fuse and the fuel pump ecu. Did a noid light test injectors 1 2 4 and 6 all lit didn't test 3 and 5. Still no start. The anti theft blinks but once I put key in ignition it stops. I have no clue what it can be anyone have any ideas??
Old 06-10-14, 07:48 PM
ttaylor993
ttaylor993's Avatar
Awfully expensive solutions without knowing what the problem is. It could be a number of things: CPS, MAF, vacuum hose. What codes is the car giving? Sometimes the codes can be misleading, especially multiple codes.
Old 06-11-14, 12:33 AM
marshun
marshun's Avatar
dont be that dude to throw parts at a car without thinking logically.
have you checked for spark?
why were the windows going up and down?
Old 06-11-14, 07:36 AM
Bbruno
Bbruno's Avatar
Messing with the door lick I guess it triggered something to cause the windows to go down. That anti theft system. Haven't check for spark only do to when spraying starting fluid in throttle it would crank over and run 1-2 seconds then cut off.
Old 06-11-14, 01:48 PM
bonesnj0
bonesnj0's Avatar
have you checked for spark? DITO!
Old 06-11-14, 05:40 PM
Bbruno
Bbruno's Avatar
I went back to do a check engine reader. P0120 tps sensor. I just replaced it and cleared code and it popped right back up. What would cause it come back on after replacing it?
Old 06-11-14, 07:32 PM
ttaylor993
ttaylor993's Avatar
Check out this thread, see if it helps.
https://www.clublexus.com/forums/is-...120-p0121.html
Old 06-12-14, 03:48 PM
Bbruno
Bbruno's Avatar
Did a coil test. They all light up
Old 10-11-14, 06:56 PM
aristoae86
aristoae86's Avatar
i have a 2003 GS300 with a Aristo swap. And im currently having problems with the fuel pump. Sometimes it works and sometimes it doesnt. On some days the car turns on properly and runs properly. Other days it doesnt crank on. It has a brand new 255 fuel pump & the problems still continues. If anyone has knowledge on this problem, please contact me. My email is jhonny954@yahoo.com... Thank you!
Old 10-11-14, 07:00 PM
aristoae86
aristoae86's Avatar
I have a 1986 Toyota Corolla Hatchback with 4AGZE swap. I need the Igniter. If anyone has one please let me know. My email is jhonny954@yahoo.com
Old 10-12-14, 01:30 PM
vijayn
vijayn's Avatar
If you know how to use a volt meter then check the voltage on the signal wire of the TPS, you should have around 0.4 - 0.6V during idle.
The supply wire should be 5V and the ground wire should be 0V.
Just back probe them and see if they are correct with key on ign.
Old 10-27-14, 09:01 PM
freshmoney
freshmoney's Avatar
did you ever find out what it is. i have a similar problem with my 99 gs300. one day the car started rough for a couple of seconds and then cut off.. i tried to restart but it just cranks and doesn't start, i replaced the fuel pump and fuel filter fuel pressure regulator.. New pump doesnt sound like its coming on. car starts sometime for a quick second and turns off... going to check for codes in the morning
Old 11-03-14, 04:31 AM
Bbruno
Bbruno's Avatar
Freshmoney, i did and it was the pump housing.
Old 11-03-14, 11:20 AM
KeyKeeper
KeyKeeper's Avatar
This whole thread makes me SMH.....
dsisoutham
01-18-16 03:16 PM
mungrin
Performance & Maintenance
01-01-14 01:14 PM
outlaw0209
SC- 1st Gen (1992-2000)
03-29-11 08:06 PM
bmarsh757
GS - 1st Gen (1993-1997)
12-25-10 04:35 PM
razgs300
05-08-10 05:49 PM
Quick Reply: 1998 (2nd generation) lexus gs300 won't start need help!!
