led window switches on door panel
Old 05-05-14, 08:07 PM
S2dannyKeo
S2dannyKeo's Avatar
Default led window switches on door panel
Hey guys i recently swapped out my grey interior for black but yet to install the door panels.
So while the door panels are sitting inside my closet i figured maybe i can swap the bulbs on the window switches for some led bulbs, I ended up taking one of the switches apart and it looks like it is an led bulb already so? has someone already done this? also i know there is going to be some solder work and i am prepared for that. But now is there a certain size bulb i should be working with as in voltage wise etc? thanks
Old 05-06-14, 03:00 PM
GSGenesis
GSGenesis's Avatar
Honestly bro they look like they may be 0603 SMD LED's but I'm not certain they are. Like these. I was going to change all mine out until I saw they were those type, unless you have good tweezers, and patience, and know how to tap forget it.... It's doable though obviously... I'll do mine one day, maybe you can verify if they are the 0603, if there not, there very dam close
http://lighthouseleds.com/led-compon...3-smd-led.html
Old 05-06-14, 08:29 PM
S2dannyKeo
S2dannyKeo's Avatar
holy flying ***** took the switches apart and they were the sqaures ones will atleast the driver side control i took the rear one apart and its an actual led bulb but i tired soldering another led bulb but it did not seem to come out do they have seprate fuse?
Old 05-06-14, 08:32 PM
rgarjr
rgarjr's Avatar
a member here sakataj has done some extensive led swapping. You should check out his threads.
Old 05-07-14, 05:53 AM
GSGenesis
GSGenesis's Avatar
I don't think there is a thread where someone actually states the exact size of the bulbs honestly, I've read through SO MANY! But if so, great! Post the link! Anyhow you know they are polarity sensitive right? If the bulbs attached opposite of there terminals I'll say, and polarities are attached to there opposites, gotta flip em.
Old 05-10-14, 06:27 PM
GSGenesis
GSGenesis's Avatar
I've got a guy that owns a led light shop that's going to give me the sizes. Stay tuned.
Old 05-11-14, 11:33 AM
marshun
marshun's Avatar
im intested in this
Old 05-11-14, 04:05 PM
GSGenesis
GSGenesis's Avatar
Just waiting on a reply, don't worry.
Old 05-12-14, 12:49 AM
GSGenesis
GSGenesis's Avatar
Okay so this is what he got back to me with, he believes they are this bulb: 0805 SMD bulbs
Like the following:
http://lighthouseleds.com/led-component-lighting/smd-leds-surface-mount-diodes/0805-smd-led.html
This is not a 100% Guarantee guys, but I'll take his word for it and spend the .20 cents to try lol
greg3852
03-28-14 03:17 PM
Gidovs
11-11-13 05:11 PM
hnb
12-22-12 04:11 PM
Ciege
RX - 3rd Gen (2010-2015)
03-19-12 09:16 AM
wcoastls
05-14-11 09:09 AM
Quick Reply: led window switches on door panel
