Removing Steering Wheel....
Old 03-08-14, 03:59 PM
RCFC89
RCFC89's Avatar
Default Removing Steering Wheel....
I've read several Threads on removing the steering wheel and they all say remove the Tabs on both sides of the steering wheel to get access to the torque screws to remove the airbag. My problem is I have the volume etc. controls on the left side and it isn't coming off. I don't won't to break it. There is a little hole the back of it but there is nothing inside to push to release the controls from the wheel. Has anyone removed this before?
Old 03-08-14, 04:46 PM
RCFC89
RCFC89's Avatar
Finally got it off. Not entirely sure why the pin hole is there. It doesn't really serve a purpose. There is basically a clip in the front and the back that holds the plastic cover on. If you take a flat head screw driver on both sides and wedge the cover pops right off. The actual volume control module still in place and held in by 2 screws. By removing the outer cover as explained you now have access to the other torque screw.
Hiep25
ES - 5th Gen (2007-2012)
06-03-18 02:18 PM
shaft1
09-07-12 01:52 PM
badx33
11-11-09 10:04 AM
snook
SC- 1st Gen (1992-2000)
10-10-09 05:48 AM
BlackRX300
RX - 1st Gen (1999-2003)
04-05-09 01:22 PM
Quick Reply: Removing Steering Wheel....
