How to?
Old Jun 2, 2018 | 08:20 PM
Hiep25's Avatar
Hiep25
Default How to?
hey I was wondering if it’ll be an easy job to change my steering wheel pad controls? Please help me out with some suggestions thanks.
Old Jun 3, 2018 | 02:18 PM
ESh's Avatar
ESh
At the back of the steering wheel or you have two plastics that cover the screws for the airbag. You need a flat screwdriver to remove those plastics. Then you have to Torx screws that hold the airbag.When you remove them you just pull the airbag and put it on the top of the steering wheel, you have to be careful with the wires for the airbag. Then you have to remove the big 17 mm Screw that holds the steering wheel. You have to remove all the connectors that goes at the sleep ring.Then you need to remove the back plastic from the steering wheel which covers two Phillips screws that holds the buttons. It’s not complicated you just have to follow the steps.
Batmobile
Oct 27, 2022 01:57 PM
Damage
IS F (2008-2014)
Sep 5, 2010 06:17 AM
badx33
Nov 11, 2009 10:04 AM
Grip
Jun 10, 2008 05:37 PM
DRFJB
Jun 8, 2005 10:40 PM
