RPM goes down when I press break and gear on D
Hi everybody,
I've Lexus GS300 2003, when I'm driving and then after press break and gear on (D), the RPM goes down (0.1 - 0.2) and the car start vibrating until I change gear to (N).
Noting that I have replaced the throttle (with used one) and cleaned it many times, but unfortunately the problem still exists.
FYI: no check engine and no error code, everything seems normal.
Kindly advise.
Kindly advise.
I haven't check the hoses around the brake cylinder, but do you think if there is a leak, then will get a lack of brake hydraulic oil??
Thanks
iModerate
The vacuum hoses he is referring to transfer vacuum, not fluid. The brake fluid will not be affected by a vacuum leak.
I solved my problem, by two things:
1- There was a big crack in the air hose, and rectified this by a glue.
http://im34.gulfup.com/usaMl.jpeg
2- They calibrate the computer of the vehicle.
Now it is performing perfectly.
TechyInAZ
RX - 1st Gen (1999-2003)
01-02-19 04:44 PM
Max Power
11-11-10 10:21 AM
