Has ANYONE passed emissions with a 2jzgte swap?
Old 10-09-13, 08:01 PM
Sceanzo
Sceanzo's Avatar
Default Has ANYONE passed emissions with a 2jzgte swap?
Like the title says.
Has anyone out there passed emissions testing with a JDM 2jzgte swap in their GS?
I have searched high and low and everything seems to end with no solution.
Note: I am not talking about inspection. I am referring to Emissions. A scanner has to be plugged into the vehicle and checked for DTCs and Readiness codes.
Would a stock GE ECU work just long enough to set readiness codes and scan?
Sceanzo is offline
Old 10-09-13, 09:17 PM
MasterKwan
MasterKwan's Avatar
If I was going to do that, I was going to look into using a USDM Supra ECU which talks OBD2. Figured if the supra could pass emissions so, could I. Technically you can't put an old motor into a newer car and pass but, I'm not sure how careful they are about that.
MasterKwan is offline
Old 10-09-13, 10:20 PM
NoUltimatu
NoUltimatu's Avatar
Jeff Tsai has. 806 RWHP and passed OBD2 inspection in Texas on E85.
Edit: I'm pretty sure he talked about it done with a plug in as well.
NoUltimatu is offline
Old 10-10-13, 04:57 AM
Sceanzo
Sceanzo's Avatar
Legalities aside. I can get everything taken care of short of the actual scan itself.
The supra ECU sounds interesting? Any links on how much work it is to swap into the GS?
Sceanzo is offline
Old 10-14-13, 04:37 PM
vbieds
vbieds's Avatar
Yes. Amd Im in Tx too.
vbieds is offline
Old 10-15-13, 07:21 AM
sinistervr
sinistervr's Avatar
JEFF dosnt have a complete swap.. he uses gte bottom ends but his vvti head and uses a aem as a piggy back
sinistervr is offline
Old 10-15-13, 02:01 PM
NoUltimatu
NoUltimatu's Avatar
You're right, I forgot about that.
Old 10-17-13, 06:01 AM
Sceanzo
Sceanzo's Avatar
What about using a GE harness and aristo ECU. Then swap ecus at inspection?
Sceanzo is offline
okinawa2jz
Performance
11-17-11 09:04 PM
SuicidnS13
Performance
09-25-11 03:52 PM
Hydro
Performance & Maintenance
02-13-11 07:44 AM
stockhatch
04-21-10 05:19 AM
Five1OH
02-06-05 06:16 AM
Quick Reply: Has ANYONE passed emissions with a 2jzgte swap?
