Actuator Motor Changed..unlock locks car lock unlocks car working opposite backwards
Old 07-11-13, 12:21 PM
iamkhanz
iamkhanz's Avatar
Default Actuator Motor Changed..unlock locks car lock unlocks car working opposite backwards
Whats wrong?
I have all 4 doors done by a friend.. when push the unlock button all 4 doors lock
(on remote and master control on driver and passenger side) and they unlock when you push lock..
And as all of our remotes with the first press of unlock, only unlock the drivers door then with the second press it unlocks all doors, it's exactly opposite lol.. so when I unlock it locks drivers door, then when I push unlock again it unlocks all doors..
What could be causing this on all 4 doors?
I'm thinking its wrong motor used or reversed polarity on motors...or do you think its programming?
Motor is basically working in reverse..
closest thing I see also with no solution posted is:
https://www.clublexus.com/forums/gs-...ock-issue.html
Appreciate your help.
Old 07-11-13, 12:26 PM
jadu
live.love.laugh.lexus
jadu's Avatar
maybe the ones for the passenger side were placed on the driver side and vice versa? just a thought
Old 07-11-13, 12:51 PM
iamkhanz
iamkhanz's Avatar
well they just replaced motors... in the actuator
Old 07-11-13, 12:58 PM
twojayzee
twojayzee's Avatar
The mabushi motors I used only had one set of tabs so they would only have polarity in one direction, but I have seen some that had tabs at 180* which would run backwards. But it could be programming too. Did you try just resetting the battery ? Or using the key in the doorhandle to lock and unlock the car ?
Old 07-11-13, 01:11 PM
iamkhanz
iamkhanz's Avatar
looking at the spec sheet in the actuator sticky...http://www.mabuchi-motor.co.jp/cgi-b..._ID=fc_280pcsc
I'm thinking the rotation on the motors they used are opposite of what it needs to be..
but any one have any other thoughts on what could be the issue here?
Old 02-09-16, 08:57 PM
disgraced
disgraced's Avatar
Any resolution on this issue?
Old 02-09-16, 09:38 PM
lexo98
lexo98's Avatar
Im pretty sure they were the wrong motors. Either replace the motors with the correct ones or rewire the harness going to the actuator
Old 06-21-16, 01:17 PM
ZeekGS300
ZeekGS300's Avatar
Did you ever find a solution to this? I'm having the same exact problem right now! I need help ����
Old 06-21-16, 01:39 PM
ZeekGS300
ZeekGS300's Avatar
Here's my link https://www.clublexus.com/forums/gs-...ml#post9528087
AfroPoker
12-20-18 08:41 AM
Foob
04-22-16 11:03 AM
lexusfan05
08-24-15 02:58 PM
Iparkcars
08-03-13 05:48 AM
SureShot
07-11-13 11:43 AM
Quick Reply: Actuator Motor Changed..unlock locks car lock unlocks car working opposite backwards
