HELP Crazy Sound and vibrating Brake pedal
Old 06-08-13, 01:16 PM
Strizel
Strizel's Avatar
Default HELP Crazy Sound and vibrating Brake pedal
My 2000 GS 300 has developed a weird sound form behind the dash shortly after being turned on. It sounds like Star Trek phasers going off.The brake pedal is also vibrating in conjunction with the sound.No warning lights or dash lights are coming on. Break fluid level is within normal limits.
Anybody have any clue what this could possibly be? I'm Not sure how to upload a video but I have put in the link to the YouTube connection. It is insanely loud.
Old 06-08-13, 02:56 PM
808Garage
808Garage's Avatar
I would check under the dash to see where that sound is coming from. Possibly around the brake pedal. Look for relays or switches. Good Luck.
Old 06-08-13, 03:15 PM
rgarjr
rgarjr's Avatar
Sup broh.. I know exactly where that is coming from. it's your ABS/brake booster that just went bad. Open your hood and get near the BMC to confirm.
Mine did the same thing about 2-3 years ago, got another used one and put it on and now it's doing the same thing.
Old 06-08-13, 05:59 PM
Dawa
Dawa's Avatar
what a weird *** noise. im not sure if its your brake booster, but i can tell you that driving with a bad booster isnt necessarily bad, your brakes will still work, you just dont have the assistance of engine vacuum. but of course that sound is annoying as hell so i would definitely want to fix it.
as for the vibration, one thing that causes vibration is warped rotors, which are very inexpensive to replace usually, approximately 30-40$ from aftermarket companies
Old 06-08-13, 06:14 PM
rgarjr
rgarjr's Avatar
Yeah it most definitely is an ugly *** sound to have blaring all the time when you drive. A lot of members on here have referred it as baby eagles screaming.
Old 06-08-13, 06:22 PM
burny
burny's Avatar
what is the part needed to fix this and how much is it? I was looking at Sewell's and there are several items listed. Future reference, thanks
Old 06-08-13, 06:28 PM
rgarjr
rgarjr's Avatar
Most owners with this problem just replace the whole brake booster/master cylinder part.
Old 06-08-13, 10:09 PM
Strizel
Strizel's Avatar
To clarify the vibration is happening when the car is stopped and feels harmonic with the sound. So basically rotors are fine and I'm sure the sound and vibration are connected.
But you guys are awesome, I will definitely check out the booster. I'm just curious if the sound is an intentional alarm for the failure or just the sound the booster makes when its gone bad.
I'll check out others threads but do you guys know if any ones posted DIY on booster replacement? Quite honestly had never heard of a booster.
Old 07-03-13, 05:55 PM
Strizel
Strizel's Avatar
After looking at part costs on Swell parts ($2300 for the entire assembly) and judging the complexity of the job I decided to let the professionals take care of replacing the master brake cylinder. Rebel Auto charge me $2100 total. Not sure if that was a good deal or not but sound decent when the cheapest I could fine the part was $2300. Scary thing was they weren't sure if that was the problem. I'm really curious if you could get away replacing just a section of the MBC.
So far no sounds with the new one.
morocco (10-04-17)
Old 07-03-13, 07:25 PM
repugnante
repugnante's Avatar
The wise choice would've been replacing that unit with an 01+ unit. But it's new and the problem went away so no worries...
Old 07-03-13, 07:28 PM
rgarjr
rgarjr's Avatar
Yeah I wonder if the OP got the 01-05 one? I had the same exact problem and just now put on 05 unit on there.
Old 07-09-13, 12:41 AM
Strizel
Strizel's Avatar
Wish I had known you could do that. I'll call tomorrow and see if they can tell me the part's year?
Old 07-09-13, 10:10 PM
KAJmapper
KAJmapper's Avatar
I would like to buy your old brake booster from you guys
Old 07-09-13, 10:11 PM
KAJmapper
KAJmapper's Avatar
Please pm me
BBea
UX Models (2019-present)
12
04-02-24 10:30 AM
Booyah
GX - 1st Gen (2004-2009)
15
02-23-19 06:28 AM
let04
NX - 1st Gen (2015-2021)
14
08-09-17 03:19 PM
DJOG
03-03-14 07:33 PM
eYezs1ck
01-22-14 08:15 AM
Quick Reply: HELP Crazy Sound and vibrating Brake pedal
