Question for those who have changed or removed rear toe links
What tool did you use to pop the link out of the spindle? I read the diy in the suspension section and that guy had the same problem (said he used a pickle fork).
I tried to use the small tie rod puller from Autozone, the opening was about a 1/4" too big.
Brought it back and got two different size separators (pickle forks). Didn't really budge.
Went to Oreillys and Pep boys, both of the ones they had were too short (depth wise).
From looking at the car, I need something with about an inch opening and 2 inches of depth. Anyone can recommend a tool to use that worked for them?
Update:
So I finally got my megan toe arms in. I got the proper tool from Napa. Evercraft tool # 776-9096. It is a perfect fit, no hammering or separator forks needed. Just pops the arms off without much effort.
Heres the link http://www.napaonline.com/Catalog/Ca...69096_00000888
Update:
If I get desperate maybe, but I know there must be a proper tool to use. I'm tired of breaking other stuff doing things the improper way. 2 reasons that would suck:
1. Live in an apartment complex, so trying to keep the noise down since technically I'm not supposed to do any car repairs even though I do all the time.
2. Knowing myself, I would somehow hit the abs wire
^^^^ I had to use it. Didn't know there was a golf emoticon.
HAHAAH, that would be my luck....
http://www.oem-tools.com/products/show/27022
This is the one I use, and it's probably the one got if you bought it at autozone. You have to position it in a way so that it grabs onto most of the spindle... basically by rotating the puller.
If you're going to use the hammer method, loosen the nut on the rear toe arm, but do not remove it full. You'll want it flushed at the end of the threaded stud so when you hit using your hammer, you do not damage the stud. Hammering should be okay since the toe arms aren't torqued down insanely tight.
AirRideFan
Suspension and Brakes
09-30-18 05:21 PM
