Fuel Pump Replacement
I have 130K on my 2005 GS300. I was thinking about changing the fuel pump as a precautionary measure. How long do these things last. Am I crazy for thinking about changing this thing?
The stock pump will last a LOOOONG time. I had a guy come in with a car that had 350k miles! Still running on the stock pump. If you really want to do some maintenance on the fuel system, then replace the fuel filter cartridge. If you let the fuel run low very often, that may cause earlier pump failure as well. If you don't then you should be fine.
Like Jeff mentioned, try not to let the gas get low enough before you fill up again. Driving with low fuel exposes the pump and damages it from excess heat. The pump is submerged in the tank to keep it cool
LoveSCs
Performance & Maintenance
11-04-21 11:41 PM
