gs400-Stereo Install...Need help ASAP WTF!?!?!?!
I am in the middle of installing my pioneer dvd2300. Ive installed a good amount of stereo so I have an idea of what to do.
I ordered this wiring harness:
http://www.amazon.com/SCOSCHE-TA02B-.../dp/B00009UHKW
Wired everything up correctly from the H/U to the harness. Plug it in to test and I get nothing. Checked my connections everything was legit. I looked at the plugs from the wiring harness to the OEM ones and I notice a couple of odd things. Many of the wires were not lining up or even being used. For example Yellow from the h/u had nothing hooked up to it from the stock plug (prob why it is not turing on)
1-Did I buy the wrong harness
2- Does anyone have a wiring diagram for the stock plugs-I can always just switch around the plugs and figure it out that way
3-WTF!!!!
3-WTF!!!!
3-WTF!!!!
3-WTF!!!!
3-WTF!!!!
3-WTF!!!!
Then you take the power wire & illumination wire connect to power wire. Find the ground wire connect it. The. To test the speaker wires, get a double AA BATTERY take a speaker wire of the same color put one end on the + & the other on the -...... Tape it all up and your good..
Get a volt tester check for a wire that gets power only when you turn the key to ecc.
You're not doing it the right way. The power and ground needs to be tapped from behind the radio. Here you go:
https://www.clublexus.com/forums/lex...ration-gs.html
Thanks for finding this and posting it. Hopefully everything goes smooth tomorrow.
I got something special up my sleeve for the install. Its gonna look almost factory.
3-WTF!!!!
3-WTF!!!!
Page 64:
http://www.pioneerelectronics.com/St...nual011111.pdf
Dont know if someone already mentioned this, but on most of those AVH model pioneers, that yellow wire from the head unit that you say is not connected to anything....is the actual power supply wire. Im about to hookup a 3300BT and the diagram in the manual tells you that the yellow is the power. So if yours isn't hooked up to anything....it could be why nothing is happening.
Page 64:
Page 64:
Here is a really easy way to do the install, in case you haven't done it yet.
Forget the harness at the factory radio. Just ignore it. Remove the glove box (there's a few screws and 10mm bolts holding it in) and look for the factory amp at the right side. There will be two plugs connected to the amp that are the exact same shape as the standard Toyota harness behind the radio. You can pull this harness full of wires all the way to the radio cavity if you pull out some clips and unravel some tape. Once you've got it behind the radio, you can wire up the aftermarket harness since those two plugs are pinned correctly.
