Vacuum Leak?!?
Old 09-21-11, 04:20 PM
sedge11
sedge11's Avatar
Default Vacuum Leak?!?
O.K. Team ClubLexus I need your help!!!
I have a 98 GS400 with 402,000 miles (not a typo).
When I first start her up she sputters a little, usually stalls. After several attemps and after warming up a bit I can take her out on the road. She accelerates slowly at first, usually get a misfire or two, but once the car reaches 2,500 to 3,000 rpm it kicks in and runs smooth and true. I have been told that I have a vacuum leak and was hoping with the support and expertise of all of you, that I may be able to resolve the issue myself. What I am looking for is, basically, where to start, what to look for, best way to find a vacuum leak, best place to get replacement hoses, etc.
I look forward to your help, thank you in advance !!!!!!!!!!!!
-Steve
Old 09-21-11, 04:40 PM
FrankT
FrankT's Avatar
Wow with that many miles, how much oil do you use?
Your symptoms suggest you might have low compression when cold.
I would try and do a compression test on all cylinders.
Not many vacuum lines in the 400 look at them all...
Good luck and welcome
Old 09-21-11, 04:49 PM
sedge11
sedge11's Avatar
Oil doesn't seem to be much of an issue, I add maybe 1 qt. Every other month, roughly 8 - 10k miles. Thanks for your speedy reply!
Old 09-21-11, 05:42 PM
GS4_Fiend
GS4_Fiend's Avatar
MAF sensor maybe no good with 400k miles? Check vacuum leaks by listening for an air suck. A stuck opened PCV is the same as having a vacuum leak. Also do a compression test to see if engine still good.
Old 09-22-11, 04:32 AM
sedge11
sedge11's Avatar
Any thoughts/opinions/answers as to why the engine changes how it performs after reaching the 2,500-3,000 rpms? Does the engine change it's air intake at that point? i'm curious why the mechanic I spoke with said definitely a vacuum leak.
Old 09-22-11, 10:19 AM
esolo98
esolo98's Avatar
Is your CEL light on, is that why you say vacuum leak? Having a 98 GS4 as well, it is fairly easy to find a vacuum leak. Just remove the engine cover and follow the hoses, it is usually pretty easy to tell that the line is broken.
Old 09-22-11, 11:06 AM
GS4_Fiend
GS4_Fiend's Avatar
Did you read mines?
Old 09-22-11, 12:55 PM
L3XOTIC
L3XOTIC's Avatar
400K?
Post pix of your odometer. Thats one hell of a milestone.
Old 09-22-11, 01:24 PM
oslouie
oslouie's Avatar
Spray brake cleaner around your engine and see if there's any change in it. When the engine idles beter, then that is where your leak is.
Old 09-22-11, 02:04 PM
sedge11
sedge11's Avatar
Default Odometer reading
Not sure if this worked, here's a picture of the odometer. . . .
File Type: bmp
jwalk0916
07-04-17 09:30 AM
ES300MM
07-09-14 07:02 AM
mk4r34
Performance & Maintenance
04-21-12 08:59 PM
jcpatin76
03-25-12 07:35 PM
VM 2
04-22-07 10:20 AM
Quick Reply: Vacuum Leak?!?
