Please help with interceptor wiring!!!
Old 09-17-11, 06:53 PM
LALEX1
LALEX1's Avatar
Default Please help with interceptor wiring!!!
I'm installing my haltech interceptor (piggy back) unit into my supercharged gs430. I have never really installed any units like this so if someone could please help me out and tell me exactly which wires I need to connect to which pins on the stock ecu.
Note this unit was removed from another sc'd gs430 so I can tell exactly which wires I need to install from the haltech unit. I'm just not sure where to plug them in, or which ecu wires to cut.
Here are some pics of the pinouts and haltech wiring diagrams.
Also wiring diagrams for srt and sfacii, just in case they help.
The wires which are already extended for use are
(pin out based on haltech wiring diagram)
grey connector
3. analogue out 1
6. signal ground
8. 5v
9. analogue in 1
black connector
1. digital in 1
5. digital out 1 "rel +"
7. power ground
from what I see I am only cutting 2 wires and splicing 3.
Simple Haltech instructions.
- Splice to +12v power
- Splice to signal Ground (low current,low noise)
- Splice to power ground (high current)
- Cut engine load signal and connect each side
- Cut engine position signal and connect to each side
Can anybody please tell me which pins I have to connect these cables to?
Also not sure whats the diference between the analogue and digital inputs outputs not sure which one goes the engine load signal, and which one goes to the engine position signal.
Thanks in advance
Old 09-19-11, 08:13 AM
LALEX1
LALEX1's Avatar
Bump anyone!!!! I know there's gotta be someone out here that understands this better than I do.
Old 09-19-11, 10:17 AM
sakataj
sakataj's Avatar
try PM'ing gillexus or the guy it came from to ask them
Old 09-19-11, 11:55 AM
LALEX1
LALEX1's Avatar
I pm'ed gillexus already. I'm awaiting a response. No way to get a hold of the guy it originally came from.
I just want to be able to drive my car safely already....
avhart
12-26-19 01:39 PM
mccurdytho
01-27-17 02:22 PM
Bliggity
Performance
20
08-07-16 01:34 AM
vampier500
Performance
12-06-08 04:40 PM
Belshe1993
04-27-06 07:39 AM
Quick Reply: Please help with interceptor wiring!!!
