Camshaft issue!!!! =[
Old 07-17-10, 05:42 PM
DangGS3
DangGS3's Avatar
Default Camshaft issue!!!! =[
Hi guys,
I have a GS3 and today my mechanics were changing my timing belt, serpentine belt, camshaft seals, crankshaft seals, and water pump. Half way thru they called me and told me an issue came up. They said who ever did my timing belt last time tighten my driver side camshaft gear nut too tight and they cannot loosen it. An on top of that the camshaft seal is going bad so its leaking oil . Would I have to swap out my whole camshaft then??? And does anyone how much it will cost me approx?
Thanks!
Old 07-17-10, 06:33 PM
bmackinnon
bmackinnon's Avatar
Tell them to get 'creative' to get the damn nut off... surely where there's a will there's a way... they can put the belt back on and that will enable them to lock down the motor so nothing spins while they put the torque to the nut..... crapsman makes a 'damaged nut' socket thing that will dig into the apparently now rounded off nut and there's no way that that, combined with an air impact wrench won't put enough torque/impact to break that nut loose.... I'd be worried about my choice of mechanics if I was informed of such.....
Old 07-17-10, 07:40 PM
porn-adkt
porn-adkt's Avatar
your gonna need a new engine
Old 07-17-10, 08:04 PM
DangGS3
DangGS3's Avatar
Thanks for the advice! I'm going to ask another mechanic on Monday to see if they can fix it.
Yea a gte would be nice. but theres an easier solution lol
Old 07-17-10, 09:21 PM
GS4_Fiend
GS4_Fiend's Avatar
Get a really Lonnnnnng pipe to crack it open.
Old 07-17-10, 09:49 PM
Alexus_300
Alexus_300's Avatar
Which camshaft is it that they are having problems with? The intake or exhaust side? If it's the intake, make sure they remove the VVTi cam cover first before they can access the bolt to remove the camshaft itself. I guess these guys have never worked on the 2JZ motor before because if they remove the valve cover itself, they will see a section on the camshaft where you can slide a adjustable wrench over to hold the camshaft in place while you break the nut loose. It's only 60 ft./lbs. so not much torque there. Hope this helps.
Old 07-17-10, 09:50 PM
GSteg
GSteg's Avatar
Which shop is this so I can avoid?
Old 07-18-10, 11:44 AM
mtparker18
mtparker18's Avatar
Nope. Replace the head worst case.
He said drivers side, so it is intake.
Old 07-18-10, 11:51 AM
sleeper408
sleeper408's Avatar
I use the one from floor jack. Super breaker bar!
OP: I hope they are able to remove the nut if that's the only thing that is delaying the maintenance.
Old 07-18-10, 11:56 AM
sjlexus408
sjlexus408's Avatar
i had the same problem taking that hex bolt out on the vvti cam, i strippexd it cuz it was on there really tight.i ended up drilling it out. but yea your mechanic will just have to be creative its all part of being a mechanic.also mine was leaking through the vvti pulley so i had to order a new one, there is a seal inside the vvti pulley as well.
Old 07-18-10, 12:53 PM
JeffTsai
JeffTsai's Avatar
My 1000ft/lb gun takes those things off like nothing
BTW, you need to secure the camshaft and prevent it from rotating by putting a big adjustable wrench where the hexagon shaped area on the camshaft is located.
Old 07-18-10, 01:47 PM
porn-adkt
porn-adkt's Avatar
what amuses me the most is not this thread but your response to my answer
Old 07-18-10, 06:40 PM
sleeper408
sleeper408's Avatar
I'm sure not everyone has one of these in their back pocket like you Jeff. lol
Old 07-19-10, 05:32 PM
DangGS3
DangGS3's Avatar
thanks for the feedback guys. gonna cost me another 300 for labor and another 150 for the vvti pulley.grand total of 930
Old 07-19-10, 07:45 PM
GSteg
GSteg's Avatar
If you've already got a good air compressor, then an impact gun will only cost you maybe $200 for a reliable one.
Keep in mind that the listed torque for an impact gun is overrated for practically all brands. What's 1000ftlbs isn't really 1000ftlbs. I've sold all my big boy impact guns and now I'm left with a dinky Kobalt impact that does almost anything my other guns did, except it only cost me $25 at the time
Quick Reply: Camshaft issue!!!! =[
