Catalytic Converter on the rocks
#31
the mechanic said that if I go with an aftermarket it will more than likely will not turn my check engine light off because of less air flow through it. I would like to go this route as well but not sure I can handle having the check engine light staring me in the face everyday.
have the exact same trouble:/
#32
If the converters are going bad, you should smell rotten eggs. I had that smell for a while, but only when I got on the pedal, which is most of the time. When my cats were completely clogged, my car would not rev past 4k even with my foot all the way down, and I couldnt get past 10mph, I checked with Lexus and yes, 2400 for both catalyc converters! I work right next to a muffler shop and they cleared whatever is inside the cats. Car runs good, but I do get an exhaust smell and a cel of course. I will be getting headers or something soon.
BTW, the mechanic told me that happens when you use cheap gas ( I don't) or when you constanly let your gas run low. This I did all the time. I would wait for the gas level to get to "E" before a fill up. Apparently if you do that, all the debris from the gas clogs your cats.
I would deff go aftermarket, no way I would pay 2400 for catalyc converters! I was reading, and its easier to get headers and run some emulator( I think that's what it's called).. You can also gain some performance
#33
Better make sure I don't trust too many dealers! The wife's 320 SLK ceramic on one side went out with a rattle inside.. Costs 1600.00 for one side 1200.00 the other OUCH!!!!
#34
I just wanted to tell you all that mine problem is fixed! Just as my cel code is described, Issues of insufficiant catalytic performance or something. If u reading the celcode expl on CL u see that it has like 3 options off typical error, To heated sensor, leaking etc.
Went to a shop aand welded and cleaned the conncetions on my cats. and woila done.
/S
/S
KingNasGS4
10-29-09 11:04 PM
