HELP! Window switch won't work, along with door lock, and seat settings on driver dR
Old 11-26-09, 12:54 PM
sh0elace
sh0elace's Avatar
Default HELP! Window switch won't work, along with door lock, and seat settings on driver dR
So long story short, I locked my keys in the trunk and didn't know you could get to the trunk from the back seat. So when AAA unlocked the car, it engaged the anti theft locks and I was no longer to open the trunk from the electric switch inside the car.
We were trying to hook the switch up to the battery and shock it with 12v to open the trunk, and also tried bridging the relay, neither of which worked, but they did spark a couple times.
Now my driver side window will not roll back up (it did roll down after), my door lock switch locks all the other doors, but not the driver side. The click locks all the doors except for driver side. And the seat setting buttons do not work.
Has anyone ever had this problem? Do you know what might be the issue?
Old 11-26-09, 02:38 PM
McKrevice
McKrevice's Avatar
check the fuses.
Old 11-26-09, 02:41 PM
sh0elace
sh0elace's Avatar
In the process but I need to get a fuse tester.
Is it possible that the ECU in the door is fried?
Old 11-26-09, 06:43 PM
timgs300
timgs300's Avatar
that's possible of course. fuses are a lot cheaper.
Old 11-27-09, 04:42 PM
sh0elace
sh0elace's Avatar
No one has ever had this problem?
Old 02-14-12, 11:25 AM
1slowsc
1slowsc's Avatar
I need help also i have the same problem. Anyone know what fuse if it is?
Old 02-14-12, 11:44 AM
21SF
21SF's Avatar
Lol i just checked every fuse yesterday. The drivers door ecu should have a fuse call FL Door or something like that in the driver side kick panel body ECU 2.
Hoefully you can fix yours i had to take my car to the dealer.
Old 02-14-12, 11:56 AM
MikeFoxx
MikeFoxx's Avatar
similar type problem here: yesterday i had my window half way down... I went to close it and instead of going up it went down. I pulled the button to go up again... and it went further down. I clicked the button fast twice and it went back up. I haven't tried rolling it down since cause its raining off and on right now... Ahhhhh i wish mine was a fuse but since it still moves i doubt it.
Old 02-14-12, 06:32 PM
MikeFoxx
MikeFoxx's Avatar
Any update shoelace? Cause now my locks arent working right. Open the door... No dome light but when i shut the door the dome came on and the locks worked. Maybe a loose connection in the door panel? I wont have time to check mine till sat.
Old 02-14-12, 06:53 PM
jriggs
jriggs's Avatar
Shoe- not sure how you where trying to jump it but there is a chance you could fryed the wiring . Check all your fuses and main wiring in the drivers door. I've had my door panels off enough times i'm rather confident there is not an ecu back there. Just a basic switch box for the windows
Sloew-Look in your owners manual there is a fuse diagram
Blackgloss - sound like your car is having issues beyond the basics. if closing doors turns on lights and up is down in your switches you probably are going to need to grab a test light and spend a lot off time tracing wires and re wiring things. Doesn't sound like the same issue.
Old 02-14-12, 06:55 PM
jriggs
jriggs's Avatar
Please excuse grammar issues in my prior post. Using the phone was proved to be a but of a pia at times.
Old 02-14-12, 07:20 PM
MikeFoxx
MikeFoxx's Avatar
I need a shot of hennessey right now lol - looks like my weekend is planned for sure. Thanx for filling in.
Old 02-14-12, 07:39 PM
21SF
21SF's Avatar
There is a multiplex ecu in each door. 260 bucks from Carson.
Old 02-14-12, 07:53 PM
babysupra
babysupra's Avatar
i just fixed this problem my windows, climate control, seats, and speedo quit. and it ended up being the fuse. if i remember correct (its dark and im not going out there right now to look due to weather) the ecu fuse on the driver side fuse box. i can look tomorrow to find out for sure tho if you dont find it.
Old 02-20-12, 05:16 AM
1slowsc
1slowsc's Avatar
Let us know what fuse and where. Im pretty sure i need the same fuse.
Tommy2JZ
Performance & Maintenance
13
01-20-19 08:55 AM
TitusKing
10-30-18 07:53 AM
sparks11
RX - 1st Gen (1999-2003)
04-29-14 07:31 PM
Begno
05-03-11 08:17 PM
dannovosel
08-08-10 04:58 PM
Quick Reply: HELP! Window switch won't work, along with door lock, and seat settings on driver dR
