weird door/remote lock/light problem.need help ASAP
Old 09-27-11, 10:52 PM
SorrGwa
SorrGwa's Avatar
did you find a solution?
Old 09-28-11, 05:43 AM
SorrGwa
SorrGwa's Avatar
first i noticed the lock didnt work, then i noticed all but the driver window didnt work from the driver side door control panel. confirmed the power lock button didnt work on both sides
so this is a list of what went wrong.
driver side door control panel:
- door lock inop
- all windows except for driver window is inop
- foot well light inop
- trigger to dome light to turn on when front doors are opened is inop
- from key remote, car can be armed, just not locked, and security can be turned on
- trunk release stopped working
- trunk release via key remote stopped working
- climate control now displays in celcius
- climate control blower inop
- auto tilt back to position of steering wheel inop (most likely from a fuse reset i hope)
- instrument cluster glows max brightness
checked and tested all possible related fuses with fuse tester.
for now, i have reset the ecu overnight, will check in the morning, well in an hour or so.
just found it very odd, never had anything happen before, and suddenly everything went haywire
Old 09-28-11, 06:50 AM
SorrGwa
SorrGwa's Avatar
- reconnect neg terminal of battery back on. (check)
- scrambling to run around to find key to turn off factory alarm (honk honk honk honk honk)
- door locks work, foot well lights back on, climate control back on, forgot to check windows.
- climate control back to F :sad face: (im up here in canada, and just cuz im asian, doesnt mean i can do math all that crazy fast)
now i fear driving when it rains, i know this is gonna happen again =/ ah well
Old 09-28-11, 08:49 AM
sakataj
sakataj's Avatar
yes i did its in this thread you also bumped
https://www.clublexus.com/forums/gs-...ible-leak.html
something is DEF leaking water onto something electrical i would assume its on the door ecu...
lets have one discussion though, respond to me in the link i posted above
Old 01-25-12, 08:09 PM
SorrGwa
SorrGwa's Avatar
so i found something.
there are actually 6 ecu's,
there is a door ecu in each door (so that's 4)
and there are the kick panel body module's, 1 on each kick panel.
lexus4me2
05-12-14 04:45 PM
lv6l
04-05-10 11:35 PM
draco
12-13-08 04:48 AM
gtmax
05-09-08 03:39 PM
Spencer
09-27-04 09:34 PM
Quick Reply: weird door/remote lock/light problem.need help ASAP
