How do I drain and fill the coolant?
Old 02-09-09, 11:35 PM
saelee39
saelee39's Avatar
Default How do I drain and fill the coolant?
I would like to know how to replace the coolant with new fluids. And how many quarts? Thanks...
Old 02-10-09, 12:41 AM
GS4_Fiend
GS4_Fiend's Avatar
Use Toyota Long Life Coolant 50/50. Buy a gallon of that and just mix half coolant and half water. The is a twisting screw right underneath the middle of the radiator that is where you drain the coolant.
Old 02-10-09, 12:56 AM
Lexiss_sc430
Lexiss_sc430's Avatar
There is a "butterfly type" screw at the bottom of the radiator, unscrew it and allow all the fluid to drain.
Now if you want to flush the system grab a hose turn on the car and allow it to heat up enough for the thermostat to open up and allow the hose water to flow through the system and drain at the bottom. Then button everything up and refill
Old 02-10-09, 08:27 AM
djspawn00
djspawn00's Avatar
I wouldn't dilute the coolant with regular water... spend a buck and get distilled water.
Old 02-10-09, 10:48 AM
PHML
Master Thread Closer!!
PHML's Avatar
Don't forget the drain plug on the engine.
Here's the official Service Manual (GS300) for you DIYers.
Good luck.
Pete
Old 09-13-10, 11:17 PM
lastguy
lastguy's Avatar
any body know the engine plug location? the service manual plot is not clear? thanks.
nparthi
05-29-23 11:41 AM
wbmx1981
Maintenance
11-09-22 12:23 PM
DREED2017
16
04-17-17 12:29 PM
fade41
01-16-16 11:52 PM
SpencerT
06-23-14 08:28 PM
Quick Reply: How do I drain and fill the coolant?
