Will these wheels fit a 2nd gen GS? i dont want to do any fender mod...
Old 02-02-09, 01:45 PM
olddog
olddog's Avatar
Default Will these wheels fit a 2nd gen GS? i dont want to do any fender mod...
need some help guys. did some searching on CL to see if i could find any info but no luck.
I am looking at a set of work eurolines
specifications are
18x9.0 with OFFSET 25 on all fours.
are these aggressive or conservative? i checked Romini's wheel fitment guide but couldn't place them in any category.
will these fit my GS without any modifications?
i plan on running 245/40/18 tires all round also. Would this be an issue.
i dont want to do any fender mods.
here is what the rims look like:
thanks
olddog
Old 02-02-09, 02:19 PM
LeXaNoMicS
LeXaNoMicS's Avatar
should be fine , depending the ride hight. I have 20x9.5 35+ offset in im all the way down on coils no rubbing no fender mods 275/30/20 ...
Old 02-02-09, 02:46 PM
Vincent123
Vincent123's Avatar
run some stretched low profile tires and you should be fine, you might have occasional rub once in a blue moon depending on how low you are
Old 02-02-09, 03:41 PM
olddog
olddog's Avatar
i am on Tein CS coilovers and i will be having 1 or 2 inches gap allround.
i really dont want low profile tires cos the roads here are not excatly nice and i drive this car every single day.
so fitment without any fender mods shouldn't be a problem? And with 245/40/18 tires?
can anyone tell me what it mmight llook like physically: flush? tucked? sitting outside fender?
please advise before i jump and buy rims that dont fit or realize i have to do fender mod(dont want to)
thanks
olddog
Old 02-02-09, 04:22 PM
LeXaNoMicS
LeXaNoMicS's Avatar
you should be fine with no modds the tire will be sunken in more than flush
Old 02-02-09, 04:38 PM
[ant]
[ant]'s Avatar
hm depends on camber as well. rear will be fine, probably a little sunken but with the chunky tyre it should look okay.
i have 19x9 +27 with -2 camber and 235/35 tyres and get occassional rub up driveways on angles. so provided you run a bit of camber and arent too low you should be about right. Front will be a little sunk but again with the bigger tyre it will probably look alright
Old 02-02-09, 04:50 PM
LeXaNoMicS
LeXaNoMicS's Avatar
oh and one more thing ...i thought i wanted to be hassle free and blah balh no mods this and that. with that said i wish i had done more research and got more aggressive offsets and widths , its not hard to shave the fenders and not have rub.
Needless to say now im looking for new ones
Old 02-02-09, 05:45 PM
olddog
olddog's Avatar
thanks alot guys....
am going to go for it. i was going to settle for 19s but i like a little bit of speed/hate sluggishness on cars when moving or starting off and i drive the car every single day... so what said to myself was that i would get what siz ecame first in any wheel that i found desirable.
if they are too small, i will live with it.....lol
afterall, at one time i thought i would never get past 17s..
Old 02-02-09, 07:02 PM
Vincent123
Vincent123's Avatar
19's look perfect on the 2GS imo
then again.. so do 20's but I dont have the funds to keep changing my mind haha
Old 02-03-09, 12:41 PM
sakataj
sakataj's Avatar
those look good but kinda remind me of the lowneharts i think they were.........? someone fill me in
Old 02-03-09, 01:12 PM
Stefwilli
Wheel Vendor
Stefwilli's Avatar
Hey Olddog just a notice that you will rub but if you can live with it, then enjoy
Old 02-03-09, 01:21 PM
LeXaNoMicS
LeXaNoMicS's Avatar
Explain , PLease !
Old 02-03-09, 01:33 PM
400DGRZ
400DGRZ's Avatar
you will be fine in the rear. the front may rub some. depends on what brand tire you go with. some are fatter than others. i suggest running a mild stretch in the front. the front wheel will probably stick out just a tad from the fender.
check out an old thread of mine. i'm 18x9 -30 and 9.5 -28
i dont rub at all and i'm flush.
https://www.clublexus.com/forums/gs-...ork-equip.html
Old 02-03-09, 03:53 PM
phillygs3
phillygs3's Avatar
You should be fine . I had 19x9 with 25 et in the front with a 225/35 tire and had plenty of room left
Old 02-03-09, 04:16 PM
LeXaNoMicS
LeXaNoMicS's Avatar
EXactly !!!!!!!!
Quick Reply: Will these wheels fit a 2nd gen GS? i dont want to do any fender mod...
