Is it safe to drive? 4 / 5 Lugs
Well, I took off my old rims, and went back to stock. I used aftermarket lugs on stock wheels, only to realize hear constant clicking when I drove it up and down the street. Live and learn!
Anyway, while in the process I snapped one of the lug bolts(the piece that sticks through the rotor) off. Guess i don't know my own strength Haha
So now, all 4 lug nuts are tightened as hard as I could...Took it for a test drive and it seemed fine...
Also, don't think it matters, but its the rear passenger wheel.
Should I continue to drive it at all or send it straight to a shop?
TIA
TIA
I've seen people drive on only four studs for a while and they were alright, but I wouldn't recommend it. The GS was designed to utilize a 5 stud bolt-pattern for a reason. Best to get it fixed as soon as possible. Shouldn't cost very much.
i drove a 96 eclipse 50 miles with only 3 lug nuts on 5 lug. I was selling the car and took my aftermarket wheels off and for some reason tore up the threads on studs on a few of them. It rode fine all the way there, but i was nervous. I laughed the hole way home from dealership thinking that they would be pissed when they saw the lug nuts gone.
iModerate
It would have been fine on 4 of 5 studs and lugs. Many less car savvy people drive cars for years upon years like this with no issue. BUT if you tightened the rest "as hard as I could" instead of the recommended torque I suggest having all 5 studs at that corner replaced ASAP. The likelihood of those additional 4 studs stripping or snapping off is greatly increased by the over tightening of them.
So I vote get them replaced ASAP. Safety First.
Almost forgot: Get the proper type Lugs for the stock wheels if did not already.
I agree about over-torqueing the remaining lug nuts, it would be a good idea to have them replace all the studs on that wheel. The studs themselves only cost a couple bucks a piece and the peace of mind is worth the extra labor.
I almost had a wheel fall off a car because a mechanic had forgotten to put a lug nut on. 2 of the remaining studs had broken and the wheel was barely holding on by 2 lug nuts. On the other hand, my buddie's girl had driven around for almost a year with a missing lug nut/broken stud and never had any problems.
I put the OEM lugs back on so that issue is fine...
I agree safety first...I don't intend on driving the car unless its to the shop.
Where could I go to get this fix? Can it be done at most say tire places? Or would it have to be done at a mechanics place? Or could it even be a DIY?
ScBouncE
SC- 1st Gen (1992-2000)
01-27-14 06:58 AM
