Steering wheel has problems going up/down
Old 05-24-05, 05:43 PM
Panerai127
Panerai127's Avatar
Default Steering wheel has problems going up/down
I have 2001 GS430 85k miles. My other problem I noticed was that when you put the key in or out your steering wheels goes up and in so you can get out, when you get in it goes to the position you saved it on, mine sometimes gets stuck and if i try to push a botton to go up or down it hesitates sometimes and gets stock, then goes, and when it does move, it makes this lame sound like the motor is about to die that moves the wheel.. Any one has any idea what this could be fixed with? Anyone has a good Lexus mechanic in NYC area to go to, refuse to go to dealer?
Old 05-24-05, 08:45 PM
BLK98GS3
BLK98GS3's Avatar
mine isnt that bad but it makes some noise once in awhile when going back up i did i just need some lube somewhere.....maybe you could try that
Old 05-24-05, 09:05 PM
chuckb
chuckb's Avatar
if you search, there is a thread somewhere about regreasing the gears
Old 05-25-05, 12:28 AM
ILOVEGIRLS
ILOVEGIRLS's Avatar
there was even a DIY fix. i cant find the link though. good luck
Old 05-25-05, 10:07 AM
Panerai127
Panerai127's Avatar
THANKS GUYS.. I WILL TRY TO FIND IT, SO REGREASING IT SHOULD DO IT? sO, YOU DO NOT THINK IT IS THE MOTOR THAT MOVES IT?
Old 05-25-05, 10:53 AM
GS3Tek
Forum Moderator
GS3Tek's Avatar
Most likely gears AND motors when you're hearing the "straining".
I had mine replaced when it was under warranty, I think both motors and gears.
kowala
05-02-17 11:46 PM
PlatSilvSc
SC- 1st Gen (1992-2000)
12-06-12 09:56 AM
meron98sc
04-02-12 06:56 PM
acenase
08-20-08 09:52 AM
ds642
Maintenance
02-13-07 06:29 AM
Quick Reply: Steering wheel has problems going up/down
