help
Old 11-03-14, 11:56 AM
khizr23
khizr23's Avatar
Angry help
why is my door sill light not lighting as well as my foot lights in my car i tested the fuse under the hood as well as under the driver dash is good i check to power on my door sill is getting power but not lightning is dere another fuse location im missing also check the passenger fuse box as well
Old 11-03-14, 12:12 PM
ItzFilyO
ItzFilyO's Avatar
Received 1,046 Likes on 661 Posts
Poor guy.. posting twice already and nobody can help this guy?
Try removing the stuff u added and return it back to stock and see if it works. Also double check the fuses and pull them out and look at it closely, they can appear fine but actually blown.
Old 11-03-14, 12:42 PM
khizr23
khizr23's Avatar
its back to stock and still no power or floor lights buts it getting powerd cuz i checked it with my tester and all the fuse is good when i run a wire to the door light to the sills is geting power and working but not working back to stock which is strange which also the stock is getting power i dk if u have to set back up somthing ?
Old 11-03-14, 12:53 PM
ItzFilyO
ItzFilyO's Avatar
Did it ever work before? When I played with the Carista programming app, I know these lights can be programmed to come on or stay off. The foot lights and door sills are tied together and maybe urs got turned off.
Old 11-03-14, 12:58 PM
khizr23
khizr23's Avatar
yeah it worked before wha happen when i install a cutomize led lamp underneath my car it worked both of them in both sides and den it jus turn off im thinking there was a fuse burned but when i check all the fuse is working and the door sill is working if i power it up with the light but not working on stock which is stupid and stock is getting powered but not turning on the door sills
Mantist
06-22-19 09:58 AM
jdsethi
12-23-12 01:07 PM
no1gsxr
02-01-10 09:06 PM
retrodrive
12-14-01 01:25 AM
retrodrive
12-12-01 12:51 AM
Quick Reply: help
