Suspension Blues
Old 02-26-15, 10:06 AM
MA70KinG
MA70KinG's Avatar
Default Suspension Blues
Just bought my 1994 GS300, shocks are bad, cant afford them just yet but did change upper control arms and lower ball joints with some meyley ones, inner and outter tie rods with some sensei 555 stuff and now I have tooooo much toe in! On both sides! :-( What else can cause this? I saw front lower subframe has a dent but i dont think enough to mess up the entire dynamics! Its lowered on tanabes, outer tie rods are fully threaded onto the inners and doesnt give me more threads to even out the toe! Everything measured the same so idk if maybe lower control arms are bad?
Old 02-26-15, 11:16 AM
TRACKMKIII
TRACKMKIII's Avatar
Are your camber and caster numbers within spec?
Old 02-26-15, 11:30 AM
MA70KinG
MA70KinG's Avatar
Visually caster looks off and camber looked ok until i messed with the lower control arm with the adjustment screw and now toe looks ok but camber is off and caster a little better
Old 02-26-15, 11:34 AM
MA70KinG
MA70KinG's Avatar
But camber screw doesnt go in all the way because off the degree measureing thing on the subframe and on the bolt but if i put everything back to normal there will be tooo much toe in... I wish i can drive it but its not driveable lol
Old 02-26-15, 11:35 AM
MA70KinG
MA70KinG's Avatar
Shes bold legged now
Old 02-26-15, 02:00 PM
TRACKMKIII
TRACKMKIII's Avatar
You will have to correct the camber and caster first.
Old 02-26-15, 04:30 PM
MA70KinG
MA70KinG's Avatar
How can i go about doing that? At least well enough to head to an alignment shop
Old 02-26-15, 04:34 PM
MA70KinG
MA70KinG's Avatar
This is her just a couple days ago
Old 02-26-15, 04:36 PM
MA70KinG
MA70KinG's Avatar
See how the front wheel is there syeering wheel is a little to the right now with steering wheel straight it looks like that maybe a little more in
Old 02-26-15, 05:05 PM
TRACKMKIII
TRACKMKIII's Avatar
If its so bad that you can't drive it I would say just tow it to a local alignment shop.
GUNRU-GS4
Suspension and Brakes
30
06-03-16 06:09 AM
PlotPoint
17
11-22-13 08:24 AM
nismofreak
10-26-12 06:37 AM
O1GS43O
06-01-10 08:34 PM
minla007
07-26-06 01:21 PM
Quick Reply: Suspension Blues
