Need Help Please!!
Need Help Please!!
My rear passenger door wont open from the inside or out and I suspect that one of the clips to the rods broke. I was wondering if anyone has an idea on how to take out my door panel with my rear passenger door closed ?
You can try removing the plastic trim piece that surrounds the inside door handle. Once you do this, you will have access to a 12mm?/phillips head screw. If you remove this screw, then you can lift the actual inside door handle awat from the door.
On the door handle you will see 2 cable lines. These are what pull the lever at the door latch and allow the door to be opened. I am guessing one is for the locking flip switch (red sticker on it, that lock the door), and the other is for the actual inside door handle. Messing around/pulling on one of these may help.
I hope this makes sense.
bagyo
SC- 1st Gen (1992-2000)
06-28-13 03:29 PM
