Ecu-Aftermarket Options
Old 08-24-14, 12:05 PM
CARSNBIKES
CARSNBIKES's Avatar
Post Ecu-Aftermarket Options
So I have tons of plans to modify my 1gs including v160/161 swap, motor rebuild, and turbo eventually... I stopped at a local Dyno shop and was recommended a new Aem v2 ecu. Any thoughts? Suggestions?
Old 08-24-14, 05:58 PM
joewitafro
joewitafro's Avatar
AEM V2 is a pretty good ecu, you will need quite a good tuner that will spend a lot of time to make an "amazing" tune though.
Megasquirt MS3-X or MS3 pro is cheaper, can be DIY, and also requires a good tuner that will spend a lot of time if you want an "amazing" tune.
Pro EFI is twice as expensive but makes an amazing tune a lot easier to achieve, tons of features. Need verified tuner/install.
Motec M800 is expensive but considered the best. Need verified tuner/install.
HKS Fcon V-Pro gold - On par with AEM V2, released in 2009 however needs to be tuned by a licensed hks tuner.
Pretty much take your pick based on your budget and features.
Old 08-25-14, 07:36 PM
CARSNBIKES
CARSNBIKES's Avatar
I want to get into diy tuning set ups, so megasquirt ms3-x or pro would be best, which would you suggest?
Altezzack
Performance
78
06-02-15 01:41 AM
speed6
Performance & Maintenance
08-14-12 09:46 PM
Ali SC3
NELOC
12-09-08 05:24 AM
V8A31
12
04-03-07 07:24 PM
kmn5
06-21-03 10:58 AM
Quick Reply: Ecu-Aftermarket Options
