please help !!!!!!!!!!
Old 02-06-14, 09:56 AM
zebroo
zebroo's Avatar
Default please help !!!!!!!!!!
Hi I would like to ask you, I changed the lexus gs430 year 2005, the head gasket, I was also taking out the motor, after installation, I can not start the engine only start | to 3 seconds and turns off when you hold the gas pedal when starting the engine and nastaruje but it intermittently as a bad valve timing, but everything I checked about 5X the timing belt is on the marks, and sprockets on the camshafts are one dot, no fault diagnostics, please help
Old 03-04-14, 08:47 PM
Titten
Titten's Avatar
Check the air flow meter connector and all fluids. Ask a mod to move your thread to the correct section, to get it more views. Good luck.
VIRGOPELO
RX - 1st Gen (1999-2003)
08-14-15 08:58 AM
sancarlos1
03-26-15 01:48 PM
zebroo
Performance
02-10-14 01:13 PM
chuydiaz
06-19-12 09:41 PM
ted17
Performance & Maintenance
08-13-05 04:21 PM
Quick Reply: please help !!!!!!!!!!
