Supra 6sp LSD in GS300 pumpkin?
Old 11-18-10, 06:30 PM
Ken'sGS300
Ken'sGS300's Avatar
Exclamation Supra 6sp LSD in GS300 pumpkin?
Will a Supra TT 6sp LSD drop into a 1st gen pumpkin?
Also, will the FD ring gear from the stock GS bolt onto the Supra LSD?
Basically I just want to install the LSD into my stock pumpkin, and am hoping to get a definitive answer. I would really hate to get that thing down and torn apart only to fnd out that something will not fit. This is my only form of transportation, so it can only be down for a weekend.
Old 11-18-10, 06:37 PM
vtec-this
vtec-this's Avatar
idk know that answer for sure but i do no that the auto tt rear end are different from the 6 speed tt rearends idk if that helps ya at all.....
Old 11-18-10, 07:15 PM
Ken'sGS300
Ken'sGS300's Avatar
Thanks, but I am pretty sure that the limited slip differentials themselves are the same. What I want to know is if the diff will fit into a GS pumpkin.
Old 11-19-10, 05:57 AM
trd4life
trd4life's Avatar
No! I went through this myself. The only lsd you can use is the supra TT auto lsd, the aristo lsd, or the 5 speed n/a lsd. The 6 speed lsd will not fit.
Old 11-19-10, 08:21 AM
Aristoman
Aristoman's Avatar
^^^ that is correct.. there is noway in hell the 6 spd LSD is fitting in the GS300 pumpkin.. but the Auto LSD is a direct swap
Old 11-19-10, 08:28 AM
countrygre
countrygre's Avatar
the 6 speed is a 12 bolt lsd and pumpkin is bigger than a tt auto 10 bolt lsd
Old 11-19-10, 08:30 AM
Ken'sGS300
Ken'sGS300's Avatar
So what you are saying is that, not counting gear ratio, a 6sp LSD is different from an auto LSD?
Does the same apply for the pumpkins? The auto TT pumpkin case is a different part number compared to a 6sp pumpkin case?
Honestly it just doesn't make sense to me that Toyota would build 2 different Torsen diffs; one for manual and one for auto.
Old 11-19-10, 12:01 PM
trd4life
trd4life's Avatar
they are different. not interchangeable.
Old 11-19-10, 12:40 PM
Aristoman
Aristoman's Avatar
Yep. here is more info
http://www.supraforums.com/forum/sho...speed+Auto+LSD
Old 11-21-10, 05:24 PM
twojayzee
twojayzee's Avatar
The carrier bearings are different sizes.
Old 11-22-10, 10:58 AM
147noob
147noob's Avatar
yeah toyota has been doing that for years look at the supra mk3 the manual non turbo lsd is like a 1way then the turbo manual and turbo auto are 1.5 way but the 1jz supras manual had torsen diffs and the 1jz auto had clutch type lsd its how toyota has always been im sure they had there reasons though mostly thought about diff gear ratios through transmissions and what diff would work best for that
XxPainxX
SC- 1st Gen (1992-2000)
16
09-02-11 10:48 PM
moto696
Performance & Maintenance
03-14-11 02:10 PM
swegs430
Performance
05-17-10 03:36 PM
lex400sc
10-28-04 03:13 PM
my_1st_GS
Performance
12-12-03 05:31 AM
Quick Reply: Supra 6sp LSD in GS300 pumpkin?
