Am I going to die?
Old 09-10-05, 09:16 PM
BigVIPness
The Green Grundel
BigVIPness's Avatar
Default Am I going to die?
Ok so today I took the seats out of my car, I DID NOT disconnect my battery cause I read nothing about that and was not told to do so. Then I started my car with the seats out to recharge the battery cause the doors and lights had been on for a while then I turned it back off after a few seconds. Then I found out you were supposed to unhook the battery so I did.
Now bryan tells me since I didn't unhook the battery and I unplugged the seats that "something something airbags will deploy"
Is that true? When the seats go back in i'm goign to plug them back in and reconnect the battery, will I be safe or will my airbags go off?
I'm so confused!!
Old 09-10-05, 09:28 PM
TLW
TLW's Avatar
eventually yes
but i think the airbags only go off if the sensors are triggered
Old 09-10-05, 09:44 PM
BLAZE
BLAZE's Avatar
No ur fine (well at least you'll live). Leave your battery disconnected and plug ur seats back in with the key in the foward position,Then connect your battery and hope for the best.....No for real the worst case is u might have your airbag light stay on. You can just go to the dealer and they can reset the code. But in the future u should always disconnect the battery. good luck
Old 09-10-05, 09:49 PM
Lexiss_sc430
Lexiss_sc430's Avatar
I dont think u'll die, I have taken out my seats a few times and I have not disconnected the battery ever. As far as I kno you should be fine... but then again I drive a SC so it might be a lil bit different from ur GS. lol
Tommy
Old 09-10-05, 09:54 PM
BigVIPness
The Green Grundel
BigVIPness's Avatar
Sweet thanks everyone! Here's the progress: (if you can call it that)
Old 09-10-05, 11:58 PM
Wald GS
O.C. Lucky Strike Fanatic
Wald GS's Avatar
Looks good, thanks for listening to my advice or else you would of had to pay the ultimate price for new airbags.
Old 09-11-05, 01:23 AM
FunGuy
FunGuy's Avatar
Naw, disconnecting the battery is recommended before disconnecting the airbags so they wont give an error. Last time i didn;t disconnect the battery and then disconnected the airbags. THe engine check and airbag lights lighted up and i was screwwed!!!!
Old 09-11-05, 03:34 PM
seeya
seeya's Avatar
I've taken them out twice without diconnecting the battery and they only blew once. So you have a 50/50 chance.
Just kiddiing it hasn't even messed with the light on the dash.
Old 09-11-05, 04:06 PM
BLAZE
BLAZE's Avatar
Oh i didn't realize your car was a first gen. You are fine, there is no airbag in your seat and the seatbelt tensioners won't trip the airbag light
worker
01-29-24 08:56 AM
JohnnyCake
06-28-23 07:38 AM
RobzKar
05-12-12 11:14 AM
bigblack06
Hybrid Technology
02-15-11 01:15 PM
shoffman
ES - 5th Gen (2007-2012)
09-11-10 08:16 AM
Quick Reply: Am I going to die?
