Sunroof sounds like tin can when you knock on glass
If I knock on the glass of the sunroof from the inside it makes a metal sound, like knocking on a tin can.
If I knock on any other window in the car, it's solid. Why did Lexus cheap out on the sunroof?
Anybody else have this issue?
Personally I don't see this as an "issue".
I don't knock on my windows, but if I did, given that the sunroof is mounted different and held in a metal frame, I would expect that it may indeed sound different than the other windows, but I don't see that as an indication that Lexus decided to "cheap out" on the sunroof.
I'm having this issue too, My Lexus is 2015 GS 350, and I found that the sunroof is making a pop noise. Still searching about this issue and how to solve it, and until this moment I haven't found any solution that could help reducing this noise.
Lexus should really be looking at this I'm sure it's not cheap to fix out of pocket
Fizzboy7
01-16-23 10:19 AM
static
ES - 5th Gen (2007-2012)
07-21-11 06:03 PM
