2013 GS odd sound muting issue...
Since a couple days ago, my GS started MUTING sound for about 4 seconds and then gain audio for 20 seconds...
{20 second of sound}, {4 seconds of silence}, {20 second of sound}, {4 seconds of silence}...
does not matter what the sound source is.
It is the oddest thing. Radio, CD, Bluetooth... even the button noises when you select something... (ding sound) they all play fine for 20 seconds and the audio goes silent for about 4 seconds... and comes back again...
Here's what i've tried:
1. Disconnect all audio, ipod, bluetooth
2. Turn Off Bluetooth radio
3. Restart the engine
From what i recall, I DID go into Apps/Info and launched the APP from the car, which is about the ONLY different activity I performed in a long time.
Does this issue sound familiar to anyone?
For example, Bluetooth always comes back to level 34, even if i set it to level 0. or 55...
Radio back to 11..
Off behavior. This is the first I'm reading or hearing of such a instance.
Might be worth getting the dealer to check it out, especially if you can replicate the issue easily.
~ Im2bz2p345
~ Im2bz2p345
Lexus Rep told me that the Computer can be reset by holding down the Volume button, So i tried and yes, it resets the computer, but sound is still no go... very annoying
Does this happen only when listening to music streaming through your phone using bluetooth?
If so, where do you keep your phone when listening to streaming music?
I had a very similar issue to what you are describing before when listening to streaming music. Found out it was due to my bluetooth signal being poor on my phone and when it is in my pocket, sometimes audio drops out and back in depending on where my leg/arm is. When I put the phone closer to the middle of the dashboard, the problem went away.
This only happens with my phone. My wifes phone is fine and the Lexus tech's phone is fine when in the pocket and streaming.
I have an iPhone 6 by the way.
pitakia
01-11-18 12:59 PM
