Having issues with dashcam tap
Old 12-20-16, 10:47 AM
needslipo
needslipo's Avatar
Default Having issues with dashcam tap
I've been trying to follow a few different guides posted on the forums for tapping the rain sensor wires to provide power to my dashcam (Street Guardian SG9665GC). It needs 1.5A, 5v.
I tried to tap one of the pink and white wires going into the drivers side plug for the ceiling console (the console for the SOS/ceiling light/sunroof buttons). On my multimeter these read as 5v, but I they do not power on my dash cam. I also tried making a tap using this 12v to 5v power supply but I couldn't find a 12v wire to tap.
Clearly I'm doing something wrong.. could someone who has done this successfully give me some advice?
Old 12-20-16, 04:24 PM
k0kong
k0kong's Avatar
I routed my dash cam to the drivers side footwell fuse box. I tested 2 fuses and found one that was powered only when the car was on.
Old 12-21-16, 03:48 AM
Mike246
Mike246's Avatar
Err, this is not a good idea.
Tapping into a wire which appears to have a standing dc voltage on it without knowing its source can result in grief. It may be a signal wire or it may not have the capacity to supply the additional current needed. At best it could stop something working or bring up a fault lamp; at worst it could damage your electrics.
The correct solution is to connect to the fusebox or back to the cigar socket at the rear of the central console.
A further word of warning. I mounted a dashcam and found that this gave rise to errors on the satnav. My display was telling me I was driving through fields about 4 miles from the road I was on. The combination of a cheapie E-Bay dashcam in proximity to the satnav antenna (under the dashboard cover) was the likely cause.
Old 12-21-16, 07:39 AM
tejanp
tejanp's Avatar
Could you tell me what fuse you tapped into please? i need to tap into that same fuse for my radar detector.
Old 12-21-16, 01:48 PM
homeboyv
homeboyv's Avatar
Tapping into the rain sensor wire for the radar detector is just fine. I've had this on my car for 2 years now with no issues. And its right there at the top, super easy to do.
chunkyda
07-17-20 04:27 PM
justYnG
IS - 1st Gen (2001-2005)
02-17-17 06:06 PM
doctorttt
12-12-13 06:42 AM
black_LS
05-08-08 09:12 AM
JWS3
GX - 1st Gen (2004-2009)
24
05-18-06 03:20 PM
Quick Reply: Having issues with dashcam tap
