Firewall Access Through Passenger Sidee
Does Anybody have any picture or can tell me how to bring the wire though the firewall on the passenger side of the car?
Yes... below the battery there is a whole about 3" in diameter where main wire bundle goes through. No picture though. You can check visually driver's side behind ABS/break system as an example (might need to remove plastic cover).
P.S. Can't remember for sure when I parted out my GS but there is a rack-n-pinion computer sitting below battery that might need to be removed too. It sounds like too much work but easy in reality...
Not sure if you are attempting to run an aftermarket amp and sub, but check out my write-up on how I did it. There is a pic of how I got through the firewall on the passenger side...
https://www.clublexus.com/forums/gs-...install-2.html
toy4life86
06-04-10 08:45 PM
toy4life86
10-28-08 06:28 PM
