Oil Change interval
On the regular GS350 It's suppose to be every 10k miles or 12 months. I'm guessing it's the same for the GS450h as well. I usually get mine changed every 7,500 miles.
Similar to the GS350, the GS450 has oil change intervals at 10K miles.
Services reminders will come on at 5K intervals so that's in-line with the maintenance schedule in your Owner's Manual and so that you can remember to rotate your tires.
To reset the warning light, you can follow the instruction posted by dchar here: https://www.clublexus.com/forums/gs-...ml#post9147417
"Resetting maintenance light:
1) Odometer must be in Trip A display
2) Turn car off
3) Press and hold odo button
4) Without foot on brake, push ignition button twice (while still holding odo button)
5) Continue holding odo button for a few seconds and watch display until lines clear
6) Release odo button"
Hope this helps,
~ Im2bz2p345
2) Turn car off
Hope this helps,
~ Im2bz2p345
DocRock143
12-07-06 01:19 PM
