Transmission clunk
Old 10-27-15, 11:44 PM
ARM350F
ARM350F's Avatar
Default Transmission clunk
Hey everyone, has anyone ever heard a clunk and then have the car feel like something from the inside is trying to stop it when using the paddle shifters in manual mode. Specifically when downshifting from 2 to 1. By the way I did a slight throttle blip, I have done this before with very smooth results but this time it really scared me, I though the transmission broke for a second; when the car did what it did.
Old 10-28-15, 07:09 AM
bclexus
bclexus's Avatar
Received 2,283 Likes on 1,627 Posts
I almost never downshift from 2nd to 1st gear - because since the gearing is so low for 1st gear when you can (if you wanted to) downshift to 1st you are already going pretty slow.
You should not be using the throttle yourself when downshifting. Let the car actually do the throttle blip itself. It has way better timing and is smarter and faster than a human.
Old 10-28-15, 08:06 AM
ItzFilyO
ItzFilyO's Avatar
Received 1,050 Likes on 664 Posts
The car's ECU won't let u do it if it's not safe. These cars are really smart and u can't downshift to 1st gear when going 80 and it will blip the throttle in M mode only and only if needed. Say ur going pretty fast and downshift, it will blip. But if ur slowly coasting and downshift it won't blip.
I do feel it's jerking when going slow from 2nd - 3rd gear and let go of the gas in M mode but no clunking.
When ur in Sport mode and in D, the car will downshift and blip automatically if it senses that ur trying to stop on a dime. Say when ur going 80 and slam ur brakes hard to a stop, it will downshift and blip for u, even if ur in D to help it slow down faster. Like I said, very smart.
Old 10-28-15, 09:36 AM
ARM350F
ARM350F's Avatar
Thanks guys this is the first car I own that does that, my old S55 requires you blip it a little so I just did it by habit.
Old 10-28-15, 10:56 AM
blacksun
blacksun's Avatar
I know exactly what you mean. I have learned to shift from 2 to 1 at around 20-25mph so the car will automatically blip and shift more smoothly. At lower speeds the car doesn't blip correctly and the transmission lurches.
Old 10-28-15, 11:01 AM
blacksun
blacksun's Avatar
BTW, I have the 6spd. If you have the 8spd you're results may differ.
Old 10-28-15, 04:51 PM
ItzFilyO
ItzFilyO's Avatar
It works the same, mine is like that too at low speeds.
Ryandthach
RC F (2015-present)
06-08-19 01:40 PM
lexixel
07-15-17 01:14 PM
ngl1145
IS F (2008-2014)
05-26-08 10:30 AM
Threxx
Performance
04-07-03 01:41 PM
Quick Reply: Transmission clunk
