F sport rotor
Old 08-26-15, 07:59 AM
richard203
richard203's Avatar
Default F sport rotor
Can f sport rotor get resurface since it's a two piece rotor? Or u gotta change rotor every brake pad change?
Old 08-26-15, 09:05 AM
dchar
dchar's Avatar
Yes they can. I have changed just pads around 25K miles. Ordered OEM pads from online, and took it to an independent mechanic rather than using the dealer. The dealer wanted way too much just to change pads.
Old 08-26-15, 09:10 AM
vinnier6
vinnier6's Avatar
You can put new pads in without changing or resurfacing rotors the first time...takes less time to swap out pads then it does to jack up the car and pull a wheel off...
Old 08-26-15, 11:02 AM
shurik74
shurik74's Avatar
Yes, you can just swap pads but if you have a little wheel shake then I would recommend to resurface
Old 08-26-15, 01:19 PM
vinnier6
vinnier6's Avatar
If you have wheel shake/vibration then you have warped rotors and need new ones....turning them won't help
Old 08-26-15, 06:06 PM
Byprodrive
Byprodrive's Avatar
Not necesarily true
Old 08-26-15, 08:14 PM
shurik74
shurik74's Avatar
Yes... that would help, they measure with a ruler if thick enough based rules/law and re-surface, I think you can do it twice in lifetime of rotors, that's what this procedure for...
Old 08-26-15, 09:11 PM
Sevn86
Sevn86's Avatar
Not on the GS but I recently had my pads changed on my 2010 RX350 around 95k (original pads) and my rotors started squealing. So I had the shop resurface my rotors. I still couldn't get rid of the squeaks and squeals so I had to get new rotors. I've learned that from now on when ever I change out my pads i will just get new rotors.
Old 08-26-15, 10:54 PM
richard203
richard203's Avatar
My mechanic say the two piece rotor is made out of soft metal so resurfacing them mostly out of spec and this my second brake pads. I have to change my brake pads every 15k. My rotor have lip on the outside and the inside. My gs have 30k mile on it.
Old 08-26-15, 10:58 PM
dchar
dchar's Avatar
Wow...must be doing a lot of track days with your GS
Old 08-27-15, 04:27 AM
vinnier6
vinnier6's Avatar
Turning your rotors won't unwarp them...
Old 08-27-15, 11:20 AM
Bartman619
Bartman619's Avatar
LOL....hopefully Centric or Stop Tech makes some affordable replacement rotors for these 2 pc rotors. Otherwise we'll be stuck with OE rotors costing $250.00+ a piece. I try not turn rotors as well. I just change pads, and the front rotors can take about 2-3 pad changes with no turning. When they start to vibrate, it's time to change the rotors. Yes you can turn them, but sooner or later the vibrations come back because the rotors got too thin from turning and get warped.
Old 08-27-15, 11:31 AM
AlpineGt66
AlpineGt66's Avatar
I like how its a 2 piece rotor but the dealer can not sell you just the ring?
Old 08-27-15, 07:18 PM
richard203
richard203's Avatar
any1 know the spec for the rotor? the minimum thickness? I tried searching on ALLDATA they give out wrong info saying its 17" and 18" rotor but im sure ours is like 13". Or if some1 have a gs350 f sport rotor laying around can you take a pic of the back of the rotor to see whats the minimum thickness on it. Thanks
Slash300zx
RC F (2015-present)
20
09-01-24 10:28 AM
kingbabar
03-16-20 06:22 PM
YviE
10-03-12 12:15 AM
jin
Suspension and Brakes
07-13-05 01:11 AM
DroppedGS
01-15-05 12:49 AM
Quick Reply: F sport rotor
