Power Outlet to Constant on instead of switched on
Old 01-08-14, 12:47 PM
sgmstr
sgmstr's Avatar
Default Power Outlet to Constant on instead of switched on
I have searched and either I have not found the right key words or there is no information on this subject... Is there a way to make the front or the rear power outlet constant on instead of ignition switched on?
Old 01-09-14, 06:51 AM
jtrue28
jtrue28's Avatar
Why would you want to do that? Sounds like a good way to run your battery down. And judging by how many people have complained about their battery being dead, I wouldn't trust this car to handle the always on feature of one or both of those outlets.
Old 01-09-14, 08:17 AM
jucytec
jucytec's Avatar
you'd need to take apart the lighter assembly and change the accessory lines to a always on 12V line.
if you get lucky, there might be a line near where you can tap into... but, if i had to do it, i'd get a inline fuse for that line as well AND have it accessible so i can easily change it if it blows... what are you trying to power anyway?
Old 01-10-14, 06:38 PM
5PM
5PM's Avatar
Mother Toyota does not allow live sockets with power off. It should be software-configurable but that will never happen.
harold2011
ES - 5th Gen (2007-2012)
09-08-17 10:54 AM
RuffinoJ
Performance & Maintenance
11-14-13 07:33 AM
hksimpson
RX - 1st Gen (1999-2003)
05-22-06 10:06 PM
DB S600
09-04-04 03:19 PM
Quick Reply: Power Outlet to Constant on instead of switched on
