Got Some Sage RCA kits!
So if anyone from the 3GS remembers these they will know what I'm talking about. I plan to get them installed after I come back from vacation or hopefully earlier if I get my car back. These aluminum blocks are an alternative to lowering your car without springs that may cause issue's with the AWD system and also keeps everything OEM. I will keep you all posted when they are installed and will post pics of the process. Also these are for the front only, not sure how it will turn out but I'm sure I'll find out. These are for a small 20mm drop so hope it doesn't look weird.
These will work with the 4GS it was confirmed on a 3IS.
http://lexi-imports.blogspot.com/201...-30mm-for.html
So these could be used to lower the front even more with drop springs?
That would solve the issue of the rear being lower than the front that is a common issue with drop springs!
