Rhino Ramps / F-Sport
Has anyone put their GS F-Sport up on Rhino Ramps yet? Just wondering about front lip clearance. I'm planning to try it out tomorrow but was just wondering before hand.
Ok so I tested out the Rhino Ramps with my GS350 F-Sport....
No Problems at all, Now to take the little cover off under there and see how easy an oil change will be.
* Dont forget to set the parking brake if you don't already have it set to auto, safety first *
While the car is up on the ramps I thought I would take a few pictures and share them with the group. I will say, this is the first car I have ever owned that is completely sealed underneath, meaning, if you run through a puddle you will most likely not get any water up into the engine bay. In any event here goes:
Here is the brake cooling intake
And from inside the wheel well
I noticed a vented cover under the transmission
Now the oil filter cover (uses a 10mm socket or phillips head screwdriver)
Ill point out that the cover has an absorbent pad to catch drips after reinstallation (a nice touch)
Which reveals the oil filter cartridge cover
And lastly the oil pan drain plug (uses a 14mm socket)
If ever concerned about catching front spoiler, use some plywood pieces in front of your ramps to get the car up a little before it hits the ramps. I do this with my Corvette and it works great.
nice work and great pics i do not forsee myself doing an oil change anytime soon, but its good to know what it looks like down there if i ever need to. i actually love the fact that it is sealed underneath but i wonder if this will cause an issue if i ever decide to clean/detail the engine bay at some point.
Nice pix. Seem like you got skills in photography.
I had a bad experience with Rhino ramps. They made by plastic and will fade/broken if leave under sun for long time. So make sure check it before each use.
One of the ramp broken when I pull up my ES. End up scratch on the rocker molding and fender.
I would cut flywood and make custom ramps and it will last lifetime.
I used to drive my GMC Duramax up on them.. thats a good 3000 lbs on the front wheels, no problems.
But as always, safety first!
These raceramps.com are said to be wonderful.
Built from the same rubber that built the space shuttle.
There is an extra special add on for vehicles like Corvettes with low ground clearance.
SST removal tool for Lexus oil filters...
I ordered the SST filter tool from Sewell, filters, washers, tools, all weather mats will be here tomorrow! Zaino stuff too
Thanks for sharing!
I find these OTC 1533 Aluminium 2 ton hydraulic racing jacks, and aluminium 2 ton jack stands very good too.
Not only is the aluminium annodising gorgeous, the Al build makes it so light to carry, compared to the old dirty looking and heavyweight steel jacks and jack stands.
The hydraulic jack can sneak under the low GS, is powerful to use, not many strokes required for a full lift, has a pretty high maximum lift, and doesn't leak oil at all.
The OTC hydraulic jack comes with a lifetime warranty.
The jack stands are a pin type for safety. I'm scared of using the ratchet-type - one slip, and it can drop one level.
The hydraulic jack lifts both front wheel off the ground, or both rear wheels off the ground.
I actually have four jack stands, so that I can hold all four wheels off the ground - great to remove all four wheels at once, and rotate etc.
For those looking to lift 3 tons, try Arcan hydraulic jacks.
A Ryobi 18V cordless 265 Ncm impact wrench is compact, tidy, and fast to use. Makes quick removal of the four wheels.
However I put the nuts back on using a Panasonic 14.4V cordless drill which can only max some 46 Ncm, for safety to avoid stripping the threads.
I use a manual torque wrench to tighten the 20 nuts to Toyota's factory recommended 106 NCm.
While a Ridgid CA-300 endoscopic camera is also very useful for looking into the engine compartment etc, without having to disassemble parts.
The CA-300 has a powerful 4xLED light for illumination, plus it can also take photographs, and even record video with voice recording onto its SD memory card.
All great for the simple home mechanic...
DeepBlue99
09-27-18 01:33 PM
