Rubbing noise up front
Old 10-03-16, 06:43 PM
Gs3500
Gs3500's Avatar
Default Rubbing noise up front
My car has a period 2 click metallic noise that corresponds to speed. It's the front left wheel and as soon as I step on the brakes the noise disappears and reappears when I let go. I've examined and it is not the brake dust shield, nor missing anti rattle clip. I'm at a loss. Could a bad wheel bearing cause this? Car seems to brake perfectly normal. It's a very faint noise and sometimes disappears all together. Any advice of what to do next?
Old 10-03-16, 06:44 PM
Gs3500
Gs3500's Avatar
Btw it's a 2008 gs350 Awd and the pads are still thick and far away from the wear indicator clip.
Old 10-04-16, 09:32 PM
RayN
RayN's Avatar
Did you check the inner and outer break pads? if you did, I suggest that you clean your brake pads and rotor, a rock might be stock between the pads mid divider, on the rotor, on the caliper, or brake hardwares.
Old 10-06-16, 06:59 PM
Gs3500
Gs3500's Avatar
No I didn't take the brakes apart yet. Any tips or tricks on doing this? Looks like it is just 2 bolts holding the caliper to the steering knuckle.
Old 10-06-16, 11:52 PM
Sodium
Sodium's Avatar
There should be a thread in the DIY section on changing the front brakes. It's from the 2IS forum, but the front brakes on the IS350 and GS350 are the same
EDIT: here's the DIY: https://www.clublexus.com/forums/sus...g-caliper.html
I wrote the torque specs down somewhere since they're not in the DIY, so I'll post them up if I find them
Old 10-07-16, 09:32 PM
Sodium
Sodium's Avatar
Old 10-08-16, 06:44 AM
Gs3500
Gs3500's Avatar
Originally Posted by Sodium
Many thanks Sodium! As I looking at the brakes, I noticed the rear pad wear indicator was on the outside of the rotor. Should I be concerned and change it to the inner caliber side? Or can I just leave it?
Old 10-08-16, 01:06 PM
Sodium
Sodium's Avatar
Glad to help! I can't say for sure since I haven't yet replaced my rear pads, but logic would dictate that both the inner and outer pads should wear at the same rate, so the wear indicator should be fine on the outside. If you post up a picture, I'll compare it to my rear pads.
Regarding your clicking problem, is it possible that your front left rotor is warped?
Old 10-08-16, 04:26 PM
Gs3500
Gs3500's Avatar
im still at a loss what it is. There is no vibration or noise when I brake so it doesn't feel like a rotor warp issue. I'm going to jack the car up on all 4s and put the car in drive to see if I can isolate the noise.
Old 10-09-16, 07:17 PM
Gs3500
Gs3500's Avatar
Found the problem. It was the brake pads. I cleaned up the shims, pads and piston surfaces. Now the noise is gone! Not sure what exactly was causing the noise but now it's all good again.
Old 10-09-16, 10:03 PM
ibidu1
ibidu1's Avatar
I was going to tell you at times I get the same noise. Usually its the center pin that holds the pads, with the wheels on I just push on that center pin and usually goes away. Put a small dab of grease on that pin.
ExplorerII
03-03-19 09:29 AM
jkayca
ES - 5th Gen (2007-2012)
09-01-16 11:27 AM
topgun129
05-19-12 06:22 AM
seivonecsu
04-12-12 05:13 PM
truenoboy
Suspension and Brakes
21
07-20-10 03:19 PM
Quick Reply: Rubbing noise up front
