lexus gs460 hesitation
Old 01-28-16, 10:44 PM
Gs46046
Gs46046's Avatar
Default lexus gs460 hesitation
A major throttle hesitation has developed in this car,that is so bad,sometimes when you put the pedal to the floor it doesnt want to accelerate at all. Feels like the car has a bout 25% power,it seems to shift very weird also,its like the car is trying to keep the rpms very low. Im not positive but it seems to occur mostly when the car is first started and still cold,or on very wet or humid days?it feels like the car is activating the traction control and the throttle plate is not opening all the way at wot?
Notice: already change spark plugs + A/T oil + filter
Old 01-29-16, 01:13 AM
isfdude
isfdude's Avatar
Check the air filter and also the mas air flow sensor.
Old 01-29-16, 01:48 AM
Gs46046
Gs46046's Avatar
Thanks for reply..
I changed the air filter + cleaning the MAF sensor.Stil the same.
Old 01-29-16, 05:22 AM
ibidu1
ibidu1's Avatar
Any check engine light?
Have you tried removing the throttle body and cleaned it real good? Also a seafoam/top engine clean?
Old 01-29-16, 06:24 AM
Gs46046
Gs46046's Avatar
No check engine light..
I will try to clean the throttle body.
Thanks.
Old 01-29-16, 08:56 AM
TRD_Power
TRD_Power's Avatar
Sounds almost like a throttle position sensor issue to me. I had something similar with my SC400 a while back. You check the fuel filter? Long stretch, but it very well could be something with the fuel delivery, and the filter is a good place to start with that. Best of luck. Keep us posted.
Old 01-29-16, 09:56 AM
tcr101
tcr101's Avatar
Who did the trans fluid? It sounds to me like the tranny fluid is low.
Old 01-29-16, 11:58 AM
Gs46046
Gs46046's Avatar
The problem solved finally by using lexus injector cleaner.
Thanks for all.
The following 2 users liked this post by Gs46046:
BeerDad (01-19-24), kiplexus (01-27-24)
Old 01-29-16, 12:15 PM
TRD_Power
TRD_Power's Avatar
Thanks for all.
Great to hear
Old 01-30-16, 12:22 AM
ibidu1
ibidu1's Avatar
Glad you figured it out! Crap gas, you may want to replace your fuel filter aswell
Old 01-30-16, 11:02 AM
isfdude
isfdude's Avatar
Glad you fixed the problem. It seems that bottle works well on our cars.
Old 01-30-16, 12:41 PM
mnjeepmale
mnjeepmale's Avatar
Where is the fuel filter located on the GS460?
Old 01-30-16, 01:28 PM
burny
burny's Avatar
under the back seat on Drivers side I believe
Old 01-31-16, 05:01 PM
sha4000
sha4000's Avatar
Magic in a bottle, hmmmm.....
Old 02-01-16, 07:34 AM
Lukas99GS
Lukas99GS's Avatar
I've never even seen that Lexus brand cleaner, did you buy that at the dealership?
Quick Reply: lexus gs460 hesitation
