I need help!! -- I need a Headlight Moisture/Dust Cap!
Hello kind folks!
I recently changed my headlight bulb. Before being able to remove the old bulbs; a clear moisture cap has to be taken off on either side...all it takes is a simple twist of the cap and voila have access to the inside headlight housing.
Well apparently after the headlight bulb install I didnt properly tighten the (passenger side) moisture cap; I discovered it after I drove for some miles and when I popped my hood to casually check my engine I noticed the headlight moisture cap fell off. I put my car on a lift, popped off the protective barriers underneath the car to see if the cap was rolling around inside...but nope.
Now some condesnsation and moisture is building up inside that passenger side headlight housing!
I need help! Besides ebay, local junkyards....can anyone please tell me of some sites I can buy OEM Lexus parts from?!
